Jersey Tom wrote:...
The amount of in-plane force the tire can generate is directly proportional to the vertical force, sure.
xpensive wrote:Jersey Tom wrote:...
Why we perhaps should be careful with statements like the above, from another thread, as it refers to the "mu" model ?
raymondu999 wrote:There's something I cn't quite get my head around now. So when F1 transitioned from grooved to slicks in 08->09, and Bridgestone decreased the width of the fronts from 09->10 to shift the balance rearwards, barring any change in compounds, wouldn't they then give the same grip given that the load is still distributed anyways, and the narrower treads of the 10/08 tyres would have more pressure applied anyways?
There's most certainly proportionality to normal load. It just isn't a constant linear proportionality through the whole load range (Coulomb model),...
Sometimes even the most prominent name-droppers on this forum manages to confuse the simplest mathematical concept.
richard_leeds wrote:Perhaps the amount of in-plane force the tire can generate is a function of the vertical force? A complex function, but more vertical load results in more in-plane force than one would get with less vertical load.
No need to get personal about it.
hardingfv32 wrote:Is tire 'vertical stiffness' the same as tire spring rate?
DaveW wrote:Just for interest, perhaps, here is an updated rig test view of tyre vertical stiffness, including some from 2011 (allegedly, GP2 & F1 tyres were the same).
hardingfv32 wrote:Are the provided tire vertical stiffness values in a similar range to other road racing slicks found in other classes?
Users browsing this forum: banibhusan, Blanchimont, CCBot [Bot], CHIUNDA, Cocles, dave34m, ecapox, FoxHound, Google [Bot], Phil, skoop, Tim.Wright, turbof1, WilliamsF1, wunderkind, Yandex [Bot] and 12 guests
