The secrets of Brembo brake system
autogyro
autogyro
Re: The secrets of Brembo brake system
riff_raff wrote:While I am not intimately familiar with the CRC materials used on current F1 cars, I do know that a few years back the CRC brake rotor and pad materials used had a fairly similar wear rate. And the thickness of each was just adequate to last the race distance without becoming thin enough to fail structurally. Of course, one issue resulting from the pads and rotors becoming thinner as the race progresses is that their thermal mass is reduced, and this will affect their heat transfer properties and operating temps.
Probably why Button was having problems with smoke from the brakes in qualifying.
krisfx
krisfx
countersteer
countersteer
How is the front/rear bias adjusted? It would appear to me that it would be most easily adjusted through a signal to the "ERS-K" as noted in this simulation. In other words, nothing but an electronic input for the "brake by wire" system.
If this is the case, wouldn't it be simpler to use a single master cylinder?
beelsebob
beelsebob
85
countersteer wrote:How is the front/rear bias adjusted? It would appear to me that it would be most easily adjusted through a signal to the "ERS-K" as noted in this simulation. In other words, nothing but an electronic input for the "brake by wire" system.
No, the ERS-K harvesting rate and the brake balance are independent controls.
Duke
Link is dead, is there another?
Kiril Varbanov
147
Duke wrote:Link is dead, is there another?
Yes, I have updated the original post. Looks like they have re-uploaded it.
Here's the video:
[youtube]http://www.youtube.com/watch?v=nH2hcF0I-bo[/youtube]
Mr Nür
Nice video. Thanks for posting. Very interesting.
FW17
168
Hamilton is thought to have switched to CI material for the German Grand Prix race itself, as Mercedes deemed the Brembo failure ‘unacceptable’ and indeed it is the second such failure for the team and reportedly the ninth in 2014 for Brembo in F1.
- Race car Engineering
9 Failures? Does anyone have any account of these?
