F1 2017 Tyre Drag Estimation
Post Reply
ayoubtech
-1
Hi , i'm new on this forum Guys. I would like to cooperate with some who can design a pirelli tyre :shock: i can do then simulation with CFD . we would like to estimate how much drag these tyres cause and i also would like to know if there's some new approaches to reduce that drag (Blown wheel hubs, FW ...) Thank you
Re: F1 2017 Tyre Drag Estimation
How would you estimate how much drag the tyres cause without doing the CFD first? :wtf:
It's entirely dependent on the flow structures the car sets up.
The problem is you're not going to know the carcass layup for distortion at speed so that may need to be eyeballed as an estimate on whichever car your wanting to model at a representative speed.
Greg Locock
233
"How would you estimate how much drag the tyres cause without doing the CFD first? "
Well I'd probably look it up in a book.
Vyssion
Moderator / Writer
PhillipM wrote:How would you estimate how much drag the tyres cause without doing the CFD first? :wtf:
I mean you could do a super simple "drag over a cylinder" calculation... :shock:
I doubt this is what the OP is after though
Dimensions F1 Tyre:
Front: 305mm wide * 670mm high
Rear: 405mm wide * 670mm high
Assuming:
Cd(Cylinder) = 1.21
rho(air) = 1.225 kg/m^3
v(car) = 300km/hr = 83.33m/s
Front F1 Tyre wrote:D = 1/2 * (rho * A(c) * Cd * v^2 )
D= 1/2 * (1.225 * [0.305*0.670] * 1.21 * 83.33^2)
D = 1052N
D = 1.05kN @ 300km/hr
RearF1 Tyre wrote:D = 1/2 * (rho * A(c) * Cd * v^2 )
D= 1/2 * (1.225 * [0.405*0.670] * 1.21 * 83.33^2)
D = 1396.6N
D = 1.40kN @ 300km/hr
#aerosaruman
Greg Locock wrote:"How would you estimate how much drag the tyres cause without doing the CFD first? "
I don't think blown hubs and a front wing will help much with that drag :wink:
ayoubtech
-1
Hi ,Thank you Vyssion for the calculations. In fact those calculations may be used for static tyre ,that doesn't rotate.
and you're neglecting a lot of phenomenons (e.g Magnus effect, Blown hubs,perturbed air from the back of the car in front etc..) . But i do appreciate a lot what you did :wink:
Vyssion
Moderator / Writer
ayoubtech wrote:
02 Apr 2017, 16:47
I know mate - that's why I said "super simple calculation". You asked for an "estimation" of tyre drag before you would then go away and do your CFD; so I "estimated" :wink:
#aerosaruman
Greg Locock
233
PhillipM wrote:
10 Mar 2017, 12:36
He said estimate, not get a super accurate answer. That's why he's doing the CFD
Post Reply
