Trying to draw an F1 suspension in CAD, but..
Post Reply
daniellammers
How are the wishbones connected to the car?
It looks like it can't be moved at all.
Does somebody have a schematic?
You won't catch me driving a race car that I have built.
- Colin Chapman
Scootin159
Re: Trying to draw an F1 suspension in CAD, but..
You're largely right. They use what's called a "Flexure" joint, which is basically a specially crafted pieces of composite material that is flexible (although still quite stiff) in one dimension, but all but immovable in the other two dimensions. You can somewhat get the idea by grabbing a notepad and trying to bend it - it will bend easily up & down, but it doesn't "compress" much at all, and it doesn't like being "twisted" (in the lateral plane) very much. Twisting in the vertical plane isn't really an issue, since there's always two of them per wishbone.
The reason they use flexures, as opposed to standard spherical bearings, is to eliminate stiction in the suspension. They are quite stiff (stiff enough you can't bend them by hand), so they do provide an element of a spring rate, but that's easily accounted for by just running softer main springs.
I should add that the joint itself is really just built into the end of the wishbone. One end is bonded to the rigid portion of the wishbone, and the other end is bonded to a titanium end piece. That end piece is then rigidly bolted to the chassis. The rectangular piece you see on the chassis where the wishbones connect is just a flexible aerodynamic cover - likely made of some type of thin plastic or rubber. The actual flexure mounting bolts would be under that cover.
daniellammers
Scootin159 wrote:
17 Jul 2017, 21:44
Thanks for sharing your knowledge!
Do you have actual schematics as well?
- Colin Chapman
henry
324
daniellammers wrote:
17 Jul 2017, 19:41
http://i.imgur.com/D528R00.jpg
They use flexures. Search for "F1 suspension flexures" and have a look at some images.
e36jon
66
Here's an older Honda F1 suspension flexure:
http://www.racetothefinish.co.uk/media/ ... 4200000000
If you look around in the "suspension" area they have full wishbones with the flexures bonded in too.
scarbs
393
Contact:
Flexures are often mixed with conventional sphericals...
Look at this on eBay http://www.ebay.co.uk/itm/322577250126
mycadcae
Contact:
can you see view in CAD, what your CAD? used
Regard,
Nik Wan, Mechanical Designer, CATIA V5/ Solidworks/Autodesk Inventor/ AutoCAD
To make simulations easier you can use all bearing type joints (spherical, roller, bushing etc) instead of flexture. Or you can simulate the flexture joint isolation then input the response into a bearing type joint.
620
scarbs flexure looks like metal ?
Scootin 159 talks about composite
and the flexure being a significant contributor to the suspension spring rate
has he felt the suspension without its springs etc ?
a typical flexure arrangement provides notionally full compliance in 1 direction ie 1 degree of freedom and rigidity otherwise
a mechanical isolator
scarbs
393
Contact:
Teams use both carbon or Ti flexures. It's largely a packaging excercise.
Ti flexures can have a T shaped end to bolt to a flat cockpit side. Carbon flexures tend be a blade to go into a slot in the chassis.
Thus the Front Top wishbone often has a Ti "T" fitting, the Lower Wishbone has a carbon blade slotting into the bottom of the tub.
Post Reply
