vis wrote:Just to have a clarification...
Can some of you expert aerodynamicists state what is the minimum distance where aero spoiling occurs?
I think is directly proportional on speed and aero load, so in Monza leading car with little aero load should be quite neutral on trailing car aero, at least at the distance being from Alonso to Massa.
It is possible, due to the low-downforce Monza settings, that the wake was large enough to affect Massa. That being said, if Massa isn't man enough to handle all the factors that go into a race, perhaps he needs to take up sewing instead of racing. It would seem that this falls under the heading of 'occupational hazard' and 'quit 'yer b!tching'.
