F1 teams to test slicks at Jerez!!!
Post Fri Nov 23, 2007 3:29 am
megz wrote:Chubbs - Contact patch has no relevance to grip? Should we race F1 cars on supermarket trolley tyres?
yeah it wouldnt make a difference... if you had a tyre 30mm wide and a tyre 300mm wide, exactly same compund etc then they would both have same amount of grip. (F= Mu x R) however it is possible to over load a tyre so i get a few people say to me "but when i had my citroes saxo and put bigger tyres on i definately had more grip!" then i think well maybe the standard tyres were overloaded and perhaps a different copund?
i cant think of a good example but i know that increasing the contact patch alone has absolutely no effect on grip levels... lots of other factors may effect grip but not contact patch.
Chubbs
Post Fri Nov 23, 2007 4:23 am
more drag i guess :lol:
As tyre marks; BS will do what they do in CCWS I guess. (big stripe on the sidewall)
bizadfar
Post Fri Nov 23, 2007 5:22 am
Carlos wrote:A Little out of context Chris. The quote refers to wear and tear on a much smaller scale than graining, almost microscopic, the irregularities refer to the almost granular texture of the track surface, the stress of the rubber as it 'drapes and deforms' on a small scale, nearing a point of overload where tensile strength is exceeded and the rubber looses bonds and starts to tear, but on a very small scale, you could call it wear, smaller than tire graining, very small like that movie where they shrink a submarine very small and inject it into a guy's bloodstream so they can battle germs, I mean really,really tiny.
Graining and blisters and chunkies show up later in the practical stuff, that's still from the preliminary, theoretical stuff :wink:
I understand, but that would make it the single point failure that causes graining. Slicks would equal less "marbles' off line, and allow much more passing attempts, and from reading thousands of posts, people dont necessarily want to see passing they want to see passing attempts THAT is what truly makes racing exciting!
If they want to gain viewership, I think reintroducing slicks in 2008 would probably be the FIA's single largest controllable variable to increase the show.
The new Concorde isnt written yet, maybe it should be added when it is.
Chris
Conceptual
Post Fri Nov 23, 2007 5:26 am
Unfortunately, your argument only is true in a perfect testing environment. I would think that it is the variance of every square mm of contact patch that makes the difference. (F= Mu X R) only if the variables are the exact same across 100% of the contact patch.
In real world conditions, that will never be the case.
Chris
Conceptual
Post Fri Nov 23, 2007 11:45 am
Chris
so what are you saying with this? that slicks will offer more grip because there is more rubber to provide more variance? doesnt make sense :S
Chubbs
Post Fri Nov 23, 2007 3:51 pm
"didnt minardi run some avon slicks ...
...anybody have any times from back then?"
if memory serves me correctly, and it's failed before, they were well off the pace... The gap was bigger than normal between them and the top teams.
That being said, I'd call the data irrelevant... Nothing was optimized. for all we know, they were doing it just to put miles on the drivetrain as set-up work would be irrelevant.
countersteer
Post Fri Nov 23, 2007 5:06 pm
Chubbs wrote:
Conceptual wrote:Unfortunately, your argument only is true in a perfect testing environment.
Allow me to pontificate (why else would you write in a forum? :)) about "the dangers of the blinding equations". First, as this is one of my "infamous" long posts, a sum up:
A wider tire:
1. When working by adhesion generates more force.
1. It runs cooler.
2. it makes more efficient use of its contact patch by having a greater percentage adhering
3. it can run at lower inflation pressure and therefore actually have a larger contact patch
4. it can have greater lateral stiffness at a given pressure and therefore keep its tread planted better
5. it can use a softer, stickier, faster-wearing compound without penalty in longevity.
Now, if you're interested in reading this, go on. I'll try to explain why without making too many amateur mistakes. So, a rant on tires:
Here we have two perfect reasonable persons, Conceptual and Chubbs, and who knows how many people more, saying that the venerable Coulomb law for dry friction is logical. Logic and science are not well connected, that's why engineering exists.
This law, as any other law, is an empirical simplification. That is the essence of science: to simplify observations using an abstract language, the language of equations.
On the other hand, I postulate that the essence of engineering is to accomodate the equations to the real world using the human experience and common sense.
I've changed the tires of my car and I've felt more grip. You put wider tires in the back and you get understeer. So, the engineer in me assumes something is wrong. I tend to believe my own eyes and my butt (which is what "feels" the grip, sorry to say it like this).
First, as Chubbs and Conceptual points correctly, grip SHOULD be equal with a razor sharp tire IF equations were correct. The fact is that they are not. Their reasoning, if I rephrase it correctly, is simple:
1. If you use a wider tire the contact area is the same. It is wider, but it is also shorter. Simple: what matters is the pressure. Conceptual and Chubbs did not use this argument, but I throw it for free. :)
2. If you use a wider tire the force you can develop is the same. Old Coulomb law takes care of that: it's insensitive to area.
That's, to put it in a harsh way, pure bull manure. ;)
First and foremost, as I've posted many times after I learned about it (so many that I'm really ashamed to give the links again, please search for "Bo Persson" in this forum) F1 tires don't even work by friction.
They work mainly by adhesion (or at least the majority of the force comes from its "stickiness"). Of course, that's not entirely true for a normal tire. When you use adhesion, is clear that the area of the patch DOES influence on grip.
Second, and crucial, picture the interface for a moment: when you push the car down, the rubber interlocks with the surface. When you turn, the rubber is dragged around the asperities as it oozes past them, but its also sheared. You could think of two gears pushed together with such force that one of them "loosing" its teeth on the process. Of course, if you increase the area, you diminish the pressure between the teeth and they "shed" at a lower rate, giving you a more durable tire. You do not want to lose the compound at such a rate (as would happen in a razor sharp tire) that you are left running on the rim after a couple of laps.
Third, if you follow the threads in this forum, you'll see that the first mathematical description of the true forces in the interface was developed in this century (around 2000, when Ferrari started to dominate!). It works by evaluating the interlocking between minute irregularities at many scales AND the molecular bonding.
Molecular bonding follows Coulomb's law, more or less, if I understand it correctly. It's what happens between dry, clean, polished surfaces, or in "natural adhesion". It depends on the materials only.
Interlocking has a limit: if you followed the "meshing gear" paragraph above, you can imagine that the harder you push a rubber tire, more and more the rubber is pressed into the irregularities, increasing the interlocking and "explaining Coulomb's law", until there is no more surface available because all asperities have been filled by the squeezed rubber.
Simple: if you "start" with a lower pressure, you reach that limit later.
Finally, there are other effects not taken in account by old Coulomb: a tire works in a thermodinamic way. It generates drag through an slip angle and this drag times the speed equals the power. That power is dissipated as heat. On a wider tire there is a large dissipating surface to radiate heat: you do not want to overcook the tire, or you lose the sticky part of the rubber faster. The second effect is that the patch is "generated" because a minute part of the wall bends. On a wider tire, the wall bends less to develop this effect.
This post is too large to talk about lateral stiffness, but I'll mention I've seen my friends racing in rallies, running at 50 psi, to increase control. There are many references of this effect.
Ciro
Ciro Pabón
Post Fri Nov 23, 2007 5:43 pm
Many of Ciro's excellent points were covered in the first link I posted and several other ideas. I went through my library of links and articles and posted 3, I could have posted 20. Why bother even posting 1? Why bother posting? This Forum, this thread makes me wonder if the propagation of ideas, knowlege; is possible. Is education possible. Is thera a point to study, research; to prompt discussion. I am begining to have doubts.
Carlos
Post Fri Nov 23, 2007 5:51 pm
Sorry, Carlos, I'm using a phone modem temporarily, every page I load takes like an eternity, so I did not read the whole thread before posting.
Anyway, if you said it, neither Chubbs and Conceptual read your post, so mine is not entirely lost, I think. :)
Ciro
Ciro Pabón
Post Fri Nov 23, 2007 6:09 pm
Ciro - You brought out points that were contained within the articles I refer to. Your post confirmed many of the points in the linked articles and your knowledge has been distilled from both study and practical experience and reflection; from your professional experience.
I'm not saying referring to authoritative sources supplies all the answers; but it is a starting point for the creativity and synthesis of an individual's thought and a doorway to productive discussion.
HEAVILY EDITED
Carlos
Post Fri Nov 23, 2007 7:30 pm
Carlos, I did in fact read your links, and I thank you for the shared wisdom of the true nature of how tyres interact with the road surface.
What I took from the info that you supplied is that:
1. Slicks grain less due to less sharp discrepancies over the contact patch (the grooves themselves).
2. In a perfect simulation, the contact patch area would have no impact on the friction generation, due to the fact that if all variables are equal, they will all "slide" at the same exact time.
3. The overall effect that moving back to slicks would be increasing passing attempts due to less "marbles" off-line moreso than increasing cornering speed.
I know that many of you are by far more educated in these areas than I am, and I deffinately want the posters to know how appreciative I am of not only gaining wisdom from their explainations where I don't really reciprocate, but also the fact that my posts on outside-the-box thinking are met with fact rather than ridicule.
One thing about me, is that my mind is always open to be changed. I know what I have learned through experience, and I know what my mind can do to run physical simulations on the fly, but I ALSO know to listen to those that present factual information contrary to my concepts and let me know that I am barking up the wrong tree.
Thanks again people, I feel that I truly have found a home on these forums.
Chris
Conceptual
Post Sat Nov 24, 2007 5:20 pm
Very sorry if already answered, don;t have time to read whole thread!
You are correct, contact patch doesn't DIRECTLY affect the grip i.e it's not in the F=Mu*R equation. However increasing a contact patch effectivley reduces the load/square inch of the tyre which, from the non-linear tyre charecteristics of vertical versues lateral force of a tyre will increase the overall grip. However you also have to factor in heating the tyres up. I have encountered race cars with tyres which are too large an area because people think the grip will be more, but they end up heating the tyres up to and maintaining an optimum contact patch tempreture, and hence the mu value for that tyre is reduced.
Mr T
MrT
Post Sat Nov 24, 2007 11:27 pm
If contact patch had no effect on grip, why is camber so important?
sorry for the confustion, i was trying some sarcasm :oops:
poorly worded
Birel99
Post Sun Nov 25, 2007 12:33 am
Birel99 wrote:If contact patch had no effect on grip, why is camber so important?
Because it does have effect on grip.
As it was clearly explained in Ciro's long post above, it's not about friction that most people refer to on this thread. It's about adhesion.
The larger your sticking plaster is - the more hair you gonna tear off your hairy leg :lol: (i.e. more grip)
modbaraban
Post Sun Nov 25, 2007 10:39 am
Slick Tyres were last used during 1997 . There were two different tyre manufactures , Bridgestone and Good Year . Bridgestone supplied smaller teams such as Prost , Arrows , Stewart , Minardi and Lola(a comet team) . Good Year supplied the BIG teams , Ferrari , Mc Laren , Williams , Benetton , Jordan , Sauber and Tyrrell (a small team with a BIG past) .
The grooved tyres first introduced in 1998 . I am sure that you can still remember that Bridgestone grooved tyres had given a boost to Mc Laren to become WC (Mc Laren swiched from GY to B in 1998). GY grooved tyres lacked in performance compared to B ones .
2009 and the slicks may be on the way back to F1 . FIA should rethink the one tyre manufacter rule again and Good Year should re-think re-entering F1 world again (time to beat Bridgestone and take a sweet revenge with the slick tyres ? , ) . Reducing downforce and increasing mechanical grip is good approach to increase overtaking and a battle with 2 or more tyre manufactures would for sure add a lot to this cause .
bar555
PreviousNext
Who is online
Users browsing this forum: CCBot [Bot], Exabot [Bot] and 6 guests
