Crystalix wrote:xpensive, if you find amazing that there is so much answers, you can delete yours, there'll be one less.
Haha, best reply on this thread, you win best come back of the day
xpensive wrote:Fantasic idea you have there Crystalix, but why limit this to the sidepods, wouldn't a larger windmill on top of the air-intake behind the driver be more efficient?
Crystalix wrote:Hum. I'm a physic student and it was just an idea. Wind mills in the desert are working well, "they get someting for nothing", as you said.
Nevertheless, I understand what you explained to me.
But why can't I say the same thing with KERS : the extra power is given by brake-energy, given by engine (no engine, no velocitie, no braking) and so we are in the same kind of circle...![]()
Only way this would work is if the 'fans' (technically they would be 'turbines') could be deployed during braking and then retracted during acceleration.
machin wrote:Ignore the original post, enough people have explained the reality of the problem now (I like the analogy of comparing it to the current cars applying the brakes whilst accelerating to "charge" the KERS system as explained by someone else above)...
The idea of an "air-brake" (i.e. retractable or controllable pitch turbine) that is used to charge the KERS instead of losing the energy as heat in the brake discs is still an option and worthy of discussion.
Users browsing this forum: Google Adsense [Bot] and 10 guests
