-Im posting a reply in several parts as im soooooooooooooo slow at typing,i did this in 1 lot an had timed out on the site and lost the lot so not going through that hassle again !
2-component wings,this was the next big change which came about as prepregs came more into use most of which were oven cured.The wings were made in 2 halfs an then cured,normally the would be a core in the laminate of nomex honeycomb or foam.The wing would be glued together with a selection of various spars/ribs glued in place depending on the size/shape of the wing.
In the area of the ribs/spars the foam would of been removed during manafacture so the glue would be acting on solid carbo surfaces.Front wings became 1 piece and became attached under the nosebox and being fitted using solid inserts that were glued in along with the spars and were drilled/counterbored etc after bonding or the wing was drilled an 2 part bobbins glued through the skins
