mep wrote:It is a function of load.
And so is a contact patch.
xpensive wrote:I typically find it wise to try and minimize parameters involved. When "Torque at wheel", is simply "Thrust" times "Wheel-radius", can we stick to "Thrust" to avoid confusion?
xpensive wrote:My comment was with regards to wheel-torque, when if you know the wheel-radius, you also get the thrust from that.
What wheel-radius did you use anyway?
xpensive wrote:OK. Your graph explains the reason for wheel-spin from zero speed as wheel-torque from 480kW becomes theoretically enormous at very low speeds. If we would toy with the idea of a mu of 2.5 and a rear wheel contact-load of 5 kN, maximum thrust is then 12.5 kN, which equals a wheel-torque of 4125 Nm with the 660 mm wheels.
Still with 480 kW of power, said thrust would be at 38.4 m/s, or 138 km/h.
In other words, under the above conditions with 480 kW applied all the way, the F1 car would have wheel-spin up to the speed of 138 km/h, is that reasonable?
xpensive wrote:Still with 480 kW of power, said thrust would be at 38.4 m/s, or 138 km/h.
Users browsing this forum: CCBot [Bot] and 3 guests
