marcush. wrote:there is a certain slope of the difusser which is the maximum you can in terms of being steep before having separation.this of course is also a question of how much air you are getting under the car .if you are running low and don´t get much air under the car separation should be a bigger issue than if your cat can walk under the thing without having to watch her head..
as you have the low plank area which is covering almost one third of the bottom area
allows for a big difusser (length) but the side difussers -for the outer ,higher areas of the floor -are very short and less effective,there was a need to work the outer sections of the underfloor harder,pulling air from them by something different then those rudimentary side difussers.
The slots in the vertical steps in the underfloor feed a second deck expanding into
a big difusser obethe centre section of the normal difusser allowing to work the stepped up side floor sections harder .
that is how I understand it.
We should team up, I do the spelling and you do the words. Exactly what I wanted to say, only better.
Suppose there's no restrictions at all on the diffuser design; what is the best thing to put? Any wing elements underneath the bottom surface of the diffuser? Would they extend backwards from the car?
