Register
Author Message
ESPImperium
PostPosted: Tue Nov 03, 2009 9:54 pm
Professional
Professional
Looks very intresting indeed. Mark Webber is testing one very soon as well as hes getting involved with Christian Horner and his other team Team Arden.
Car specs look like this:
Monocoque and Bodywork
Survival cell – Sandwich Carbon/aluminium honeycomb structure designed by Dallara.
Front and rear wings – Carbon structures designed by Dallara.
Bodywork – Carbon – Kevlar – Glass composite structures designed by Dallara.
Safety standards
FIA F1 2006 safety standards
Front side rear and steering column impact tests.
Front and rear roll hoops, impact structures and monocoque push tests.
Wheel retainer safety cables.
Suspensions
Front and rear double steel wishbones, pushrod operated, twin dampers, helicoidally spring suspension.
Adjustable ride height, camber and toe.
Two way front and rear adjustable Koni dampers.
Front and rear adjustable anti-roll bar.
Engine
Engine development achieved by Renault F1.
Renault 4 cylinder 2 litres turbo charged 280 HP @ 6500 rpm.
Fly by wire throttle system.
One rebuilt per year only.
Gearbox
6 speed longitudinal sequential Hewland gearbox.
Electro-hydraulic command via paddle shift from steering wheel.
Pure two pedals car – clutch paddle on steering wheel.
On board starter.
Hewland ramp differential.
O.Z. racing wheels
GP3 series specific Pirelli slick tyres
Steering system
Non assisted rack and pinion steering system.
XAP carbon steering wheel with dashboard, marshalling display, gear change and clutch paddles.
Brakes
4 pistons monobloc Brembo callipers.
Brembo steel brake discs 280x18.
Brembo pads.
Fuel cell
FIA standard.
Electronic features
Magneti Marelli Marvel 8 ECU/GCU including data logging system.
XAP power supply management unit.
F1 Marshalling system pre-equipment.
Beacon receiver.
Camera equipment
New generation roll hoop, nose cone and face shot camera pre-equipment.
http://www.gp2series.com/en//website/20 ... cleid=2292
http://www.gp2series.com/en//website/20 ... cleid=2612
http://www.gp2series.com/en//website/20 ... cleid=2581
Pics of the car:
dumrick
PostPosted: Wed Nov 04, 2009 1:20 am
Professional
Professional
Formula 3 is possibly the last formula (bar F1) where development is still open and that is technically interesting (and formative). So, in a way, I hope GP3 turns out as uninteresting and unsuccessful as Formula Master or Formula 2. However, given the success of GP2, I'm not betting on it...
Scuderia_Russ
PostPosted: Thu Nov 05, 2009 8:42 am
Champion
Champion
I've worked on similar cars to this and the spec all sounds like pretty good stuff. Dallara make very good quality, very well thought out cars.
"Whether you think you can or can't, either way you are right."
-Henry Ford-
Display posts from previous:  Sort by
Similar topics Forum  Replies   Views   Last post
No new posts Aerodynamics help.. BMW M3 vented hood design Off topic chat
by Guest View the latest post
on Sat Nov 29, 2003 11:06 pm
No new posts EJ14 design Aerodynamics, chassis and tyres
by Irvingthien View the latest post
on Mon Dec 08, 2003 10:39 am
No new posts Powertrain Design Engine, transmission and controls
by riff_raff View the latest post
on Sat Oct 11, 2008 6:00 am
No new posts Rear Wing Design Aerodynamics, chassis and tyres
by pyry View the latest post
on Mon Mar 01, 2004 2:31 pm
No new posts Track design Engine, transmission and controls
by F1freak View the latest post
on Sun Mar 28, 2004 3:40 am
Jump to:
Who is online
Users browsing this forum: No registered users and 2 guests
Donate
Link us
