open deck vs closed deck
Post Wed Nov 25, 2009 5:49 am
What are the pro's and cons to each and which one does Formula 1 teams build
Spencer
Shrek
Post Wed Nov 25, 2009 6:17 am
Shrek wrote:What are the pro's and cons to each and which one does Formula 1 teams build
the open deck is cheaper to build
But the closed deck is better in case of rain
in the high dollar world of F1 the closed deck is preferred for the entertainment of sponsors
"The question isn't who is going to let me; it's who is going to stop me."
flynfrog
Post Wed Nov 25, 2009 3:08 pm
=D>
Superb...
IMPERATOR REX ANGLORUM
CMSMJ1
Post Wed Nov 25, 2009 3:16 pm
Depends on the dealer, but I prefer counting cards myself.
xpensive
Post Wed Nov 25, 2009 7:12 pm
i mean the engine block
Spencer
Shrek
Post Thu Nov 26, 2009 12:20 am
I hate having to end this merciless piss take HAHAHA. Fair play Shrek for staying cool!
Open deck is done because it is cheaper to produce, the mould can be withdrawn intact and used again but it produces inherantly weaker blocks. The cylinder has less support at the most critical point, a small increase in cooling ability near the hottest part of the engine gets it an honourable mention with regard to advantages other than cheapness.
Closed deck is better for performance as it helps resist deflection caused by combustion pressure at T.D.C. It also creates a more stable and consistent face for the head gasket to seat on. Downside is the mould has to be sand or equivalent and is lost in the manufactuing process, longer set up time and the casting has to be carefully cleaned.
Some mass market high performance engines use open deck blocks, there are ways to get around the disadvantages and you should definatly not take this as an indictment of open deck designs, but if performance is the objective and money is no object bracing the cylinder walls against the structure of the block is the best solution.
safeaschuck
Post Thu Nov 26, 2009 12:46 am
the reason i brought this up is that Dodge's new cup engine is open deck and hotrod.com and the magazine says that this also helps the block to not distort when tightening the bolts and another thing is the gasket shaped like the block or the head?
Spencer
Shrek
Post Thu Nov 26, 2009 7:30 pm
Well now, Nascar rules escape me the moment but I would imagine that they use road car based blocks. And by this I mean a block which would pass as a road car block under scrutiny but may be sort of 'blueprinted' at the casting stage, i.e. maximum metal condition.
If Dodge are updating their engine block chances are it will have had a full re-design, the bore spacing may have changed and the wall thickness of the cylinders may have increased. Switching to an open deck block alone would not improve the deformation you get from head bolt crush.
come on Shrek, you are clever lad, you understand how the engine bolts together eh? The Head gasket has to be shaped like the block AND the head dosen't it? After all one is just a mirror image of the other!
I suppose you could say that because a typical head gasket only has holes where the cylinder head water galleries are that it looks more like the head, but (if the block it sits on is open deck) BUT...
There are many ways to seal a head, a gasket is just a nice neat way to do it, some tuned engines will use individual solid rings on each cylinder and a seperate gasket which mainly does the water jacket sealing. In the case of an open deck block it is possible that the water jacket need only be sealed around the outside edge, so in this case I guess you could say that the gasket was more like the block, but you won't find very many done that way.
Ole!
safeaschuck
Post Thu Nov 26, 2009 11:28 pm
what about a closed deck having better gasket sealing
Spencer
Shrek
Post Fri Nov 27, 2009 12:15 am
Well, a closed deck gives you a more rigid block. It's harder to manufacture for reasons evident. It's also evident you'll have a better gasket support and a larger area to "resist" the push of the air inside the cylinders. I have no idea that it made the block easier to distort. Why? Intuitively it seems the contrary would happen.
Anyway, many people could not know what a closed deck is, so there you go.
Closed deck: the water holes are half closed.
Semi-open deck: they're not as closed, (duh) but there are some ribs in place.
Fully open deck: there is a clean space between the cylinder and the block external surface.
I was not able to find pictures of an F1 block, recent or old. I have plans for a Cosworth but I was not able to distinguish the kind of deck. Perhaps some member would be so kind? Thanks, you guys.
Ciro
Ciro Pabón
Post Fri Nov 27, 2009 1:13 am
You know, I can see where the open deck could be better for cooling, and have a re-usable cast, but I cannot see what else it would be better at... Except for maybe some weight savings?
About the head gasket...
After changing a few in my youth on various cars that I had owned, I always wondered why there even WAS a gasket there to blow in the first place... I always thought that machining a 1mm trapezoidal rib onto the head, and a matching trapezoidal groove on the block at 1.25mm would give great sealing that COULDN't blow out... An with the added .25mm (or so), you could even add some Loctite to it.
I'm sure that it would need to be added at the design stage, and not able to be added to an existing casting, but when you are changing your 4th head gasket on as many cars within a 2 year stretch, you will come up with ANY reason that it is the designers fault for your troubles...
Conceptual
Post Fri Nov 27, 2009 1:19 am
I havent seen the decks of a F1 car... completely. But this can gives us a clue:
Some pics from a Cosworth V10...
What I have not ever seen are the decks of a Top Fuel engine :mrgreen:
Belatti
Post Fri Nov 27, 2009 1:28 am
Nope. You cant. Even with block and head from the same material, they expand differently due to temp. Also an engine block is not that rigid, it torsions and the gasket is the one in charge to absorb diferences. Without that differences, combustion gases, water an oil could mix up.
And I guess changing 4 gaskets in 4 different cars in 2 years time is not a design problem, but bad luck :lol:
Belatti
Post Fri Nov 27, 2009 1:32 am
About the "grooved" head & Loctite concept by Conceptual, some Ford racing engines I know, like Zetec, Cosworth and Duratec can use bimetallic or solid copper gaskets. In that last case you have to fit a ring on a groove on the head (you have to machine it, altough some models have "weird" rings that serve the purpose). This ring "bites" into the copper guaranteeing the seal.
Gaskets are also there to separate oil recycling into the cylinder head from water running around the block, so I'm not sure how good your machining would have to be (oil-proof, so to speak) to have a gasket-less head, specially when it heats, expands, cools and contracts. Besides, you know, the things inside are moving at 10.000 g's or so, so, hard to do, I'd say. And, "extra-besides", why? It's not like you're saving money, let me tell you.
EDIT: Thanks, Belatti, our posts crossed. Is that a closed deck and are those copper gaskets in your pictures or am I already blind? I'd say "blind", but... what's the story?
Ciro
Ciro Pabón
Post Fri Nov 27, 2009 2:19 am
I only can see copper coloured (but not copper definitively) valve seats.
I can see no gasket, and but a groove in the outer part of the block, where the deck its open. That engine is cutted for an expo so maybe the gasket was removed.
About the metalic gasket you mention, of course there are different materials for gaskets, the thing is you need something that compresses and moulds between block and head. Or I think so.
Here, another Asiatech (ex Peugeot) pic, probably from 2001/2002:
Belatti
Next
Return to Engine, transmission and controls
Who is online
Users browsing this forum: No registered users and 3 guests
