What compression ratios are current (F1) engines running?
A colleague told me last week that otto-engines for motorcycles can run compression ratios up to 1:13.
I thought that this would lead to high peak pressures because of the isochoric process during combustion.
There must be a point(compression ratio wise) where the peak pressure goes over the peak pressure of a diesel engine.
I think peak pressure depends on engine revolutions. Because the time for combustion will go into expansion phase of volume (piston already going back) and therefore you get more of the isobaric process (diesel like).
