WhiteBlue wrote:I would challenge the 5 kN vertical force. Which F1 car would have a downforce less than the legal minimum weight? Drag coefficient also looks a bit low. AFAIK the F1 cars all come in above 1.0.
Ciro Pabón wrote:WhiteBlue wrote:I would challenge the 5 kN vertical force. Which F1 car would have a downforce less than the legal minimum weight? Drag coefficient also looks a bit low. AFAIK the F1 cars all come in above 1.0.
Well, this force works only in the rear end. The downforce in the front end is of no significance for traction, as you can easily imagine. Also, the rear end weight, even taking weight transfer in account is NOT equal to the weight of the car (duh).
What drag coefficient would you suggest?
I am not sure if it is KN or Kgf, btw. Sorry, I haven't checked again what I calculate years ago, I just reposted... Finally, I am pretty sure that the speeds you get by this method are OK: when I used the engine sound in karts, downforce was inexistent, of course.
Ciro Pabón wrote:The total vertical force is more or less 5 kilonewtons at 250 kph (cell B13).
Ciro Pabón wrote:Wheel spin stops at top speed (acceleration equals zero)
Return to Engine, transmission and controls
Users browsing this forum: No registered users and 4 guests
