Mikey's 2012 F1 concept
Post Fri Jan 13, 2012 9:27 am
After many weeks of procrastination I've finally finished the preseason spec of my F1 model. I've gone a bit aggressive on this one (but then everyone says that these days) and I'm open to any criticism (as long as you've got a good reason :lol: ) or further ideas. I'll post some pics tomorrow and start explaining what I've come up with. Hope you like it. :D
I've found a way of ducting exhaust right to the diffuser edge like in 2011 and created a new wheel fastener that could allow sub 2 second pitstops see them here --> My 2013 F1 Concept Project
MIKEY_!
Post Sat Jan 14, 2012 7:07 am
Ok here it is...
(the flap shape is something I picked up from ringo a while back, thx for that one mate)
Ok the nose itself is based entirely around a mclaren style under-nose splitter to get as much air as possible to either side of the nose and around the car. The bulge on the top of the nose is also there so split air to either side (cause a proper splitter here is illegal).
The sidepods are quite high and bulky at the front (I decided to move as many components to the front of the sidepod as possible to free up space at the back).
The airbox is an interesting one. I'm not sure if this is legal but I discussed it in another thread and no-one said it would be banned. This basically is another version of the roll blade but with a tall skinny inlet and much of the roll structure itself exposed.
Don't worry those are not exhaust pipes along the rear floor, they are exits for the radiators, not sure it would work very well (certainly worse than an EBD) but it should give some sealing I'd have thought.
BTW those notches on the front wing (lowest plane) are intakes for the FW F-duct system.
More to come later including better pics of the rear end. :D
MIKEY_!
Post Sat Jan 14, 2012 7:12 am
Wow... a literal "model!"
How do your front wings look? It almost looks like you have double decker front wings.
失败者找理由,成功者找方法
raymondu999
Post Sat Jan 14, 2012 7:53 am
Mikey where is the exhaust exit?
NonNewtonic
Post Sat Jan 14, 2012 12:02 pm
Newtonic - trace the top of the sidepods to the back. There are two ( one on each sidepod) pipes to the back.
失败者找理由,成功者找方法
raymondu999
Post Sun Jan 15, 2012 12:49 am
I'll post a pic of the FW with the cascade removed so you can have a better look.
MIKEY_!
Post Sun Jan 15, 2012 11:24 am
Well done Mikey, you've got some good concepts :) but surely that front wing isnt legal.The overall shape is out I think, and can I ask what your logic is for the front wing elements to only cover half the area allowed, but yet taking up most of the footplate space?
Looking forward to seeing it with the cascade removed, if that'll help :)
jordangp
Post Mon Jan 16, 2012 6:31 am
I see you've taken a more literal approach to the "flexi wing" concept! :)
Could you please post some underbody pics?
Good job btw!
Join the chatroom during GP weekends!
mx_tifoso
Post Mon Jan 16, 2012 10:24 am
is there more going onto the front wing?
allstaruk08
Post Mon Jan 16, 2012 9:14 pm
the rollhoop can be more radical methinks -just a keel sticking up into the air and meeting the minimum dimension requirements of the regs .Starting the airbog opening aft the blade type roll hoop you can really shed a lot of cross section in that area and gain a lot of clean flow to the rear wing..maybe the airbox is a bit short but who said you need all the length?
marcush.
Post Tue Jan 17, 2012 3:25 am
The front wing flaps are set as far as possible outboard (mostly in front of the tires) to allow more air flow to reach the front of the floor and the rear of the car. With the reduced need for front DF (due to the expected drop in rear DF) the wing could either have less AoA along it's length or have the inner areas of the flaps removed as I have done.
MIKEY_!
Post Tue Jan 17, 2012 4:09 am
Here's some more:
(cascade still attached)
One small (probably illegal) modification is the little flap behind the cascade. It attaches to the outer part of the footplate and will cause it to flex downward thus sealing the wing. I doing this it would probably move out of the maximum dimensions for the FW (although that could be solved if it's a problem). It also means the flap can't attach to this outer flexible section. The point of flex is the cut line on the footplate, it's hard to see in these photos but it's there. I need to think more about this as I envisage a big vortex occurring as the footplate separates. (Another version on the way)
mx_tifoso: I'd be wasting your time, the floor has no step or plank (it's to hard to build right now, I'm working on it) I can show you the diffuser if that helps. I've also got a similar system to the one on the FW footplate coming along. In theory a diffuser version might be possible as well.
marcush: think you could make a diagram of your idea, I'm not sure I quite understand.
MIKEY_!
Post Tue Jan 17, 2012 5:06 am
Interesting. So you're choosing to basically use a half(ish) length frontal flap; so that you can feed more air into the diffuser... sounds very interesting to say the least.
Is the cascade actually like a "bridge?" Kind of like the 2010 Spa-spec McLaren cascade that Jenson used?
失败者找理由,成功者找方法
raymondu999
Post Tue Jan 17, 2012 8:04 am
raymondu999 wrote:...
The fact that you remember what type of wings someone used at a specific race is incredible. :)
Mikey, diffuser pics would be more than fine. I was just wondering how you did the entire car including what's not normally visible.
mx_tifoso
Post Tue Jan 17, 2012 8:40 am
Why thank you mx :mrgreen:
For reference, here was what I meant:
Hamilton
Button
失败者找理由,成功者找方法
raymondu999
Next
Return to Engineering projects
Who is online
Users browsing this forum: No registered users and 2 guests
