LB02 - Astracrazy
Post Sun Jul 15, 2012 6:54 pm
So after learning sketchup etc with LB1, now planning for next year.
First tests (first ever cfd test i've done) on RW1
Drag 551N Downforce 1188N
As this is the first test ive done what sort of things should i look for to improve the wing?
astracrazy
Post Sun Jul 15, 2012 7:10 pm
I would say that testing the wing alone is not a correct way to do things. As you probably know, the rear wing is located at the back of a F1 car. Therefore the air has to go first through the whole car before reaching the rear wing. So the air flow is not what your second pictures shows : straight. I would say that before you start simulating, you should first make the whole car ! :)
I have no opinion on your first rear-wing but it looks to produce quite a lot of downforce judging by the angle it has. Only my 2 cents, but really you should first make the whole car !
Olen Sveitsista mutta mun sydän on Suomea :)
>> Follow my "Subaru Impreza Pikes Peak" project! <<
MadMatt
Post Sun Jul 15, 2012 7:16 pm
What did you use for CFD?
RicME85
Post Sun Jul 15, 2012 9:30 pm
Matt - your 100% right :) . Mainly i'm doing it because learning to use solidworks was a lot easier just on a rear wing. Ideally i'd create the whole car 1st then test the rear wing, but i'm not sure that my computer could handle that all together. I'll obviously try to add bits to the simulation to see what happens.
Ricme - solidworks, took all sunday (today) to work it all out (finding different tutorial etc) i can write some quick instructions for you? It is quiet simple once you know.
As i said, Matts right, but in terms of just the rear wing (or any other simulation) what should i look for to make improvements? Using the rear wing as an example. New to reading into cfd results :)
Thanks
astracrazy
Post Sun Jul 15, 2012 9:40 pm
astracrazy wrote:Matt - your 100% right :) . Mainly i'm doing it because learning to use solidworks was a lot easier just on a rear wing. Ideally i'd create the whole car 1st then test the rear wing, but i'm not sure that my computer could handle that all together. I'll obviously try to add bits to the simulation to see what happens.
Thanks
when I look into cfd results it depends on what you are looking for, low drag, high downforce
or what I look for is to develop by lowering drag and increasing downforce, on each wing design, (and yes this can be done)
:D
yes there is a full car in front of it, but if you are purely developing the rear wing and learning about wing design, then running it solely on its own isn't any harm, as it can teach you what works to increase df and reduce drag,
however it doesn't mean that that rear wing will work the way you intend with your car you are designing without CFD on the whole vehicle :D
Budding F1 Engineer
N12ck
Post Sun Jul 15, 2012 10:15 pm
Please PM me!
Dan Cottrell
Master Of Innovation!
CottrellGP
Post Sun Jul 15, 2012 10:17 pm
CottrellGP wrote:Please PM me!
me or him or both :lol:
Budding F1 Engineer
N12ck
Post Mon Jul 16, 2012 7:20 pm
Him :P
Dan Cottrell
CottrellGP
Post Wed Jul 18, 2012 8:21 pm
Heres a little update to the rear wing (RW1-1), can anybody give me any tips where i can find improvement by reducing drag from the below pics. I have made some small improvements so far
rw1 drag 551N downforce 1188N
rw1-1 drag 532N downforce 1206N
astracrazy
Post Wed Jul 18, 2012 9:00 pm
can I see your cutouts on the rear wing endplates, I may be able to give some advice on them :D
Budding F1 Engineer
N12ck
Post Wed Jul 18, 2012 10:00 pm
here you go
astracrazy
Post Wed Jul 18, 2012 10:42 pm
astracrazy wrote:here you go
Aerodynamically they will do nothing but cause drag, take a look at f1 wings currently, the slots arent just cutouts, they are louvres, they are meant to reduce the surface drag of the endplate :D
Budding F1 Engineer
N12ck
Post Wed Jul 18, 2012 10:43 pm
I have always found rear wing louvres the most difficult things to design. Never designed any I would consider 'good'. Note that most of my designs don't have them because I can't design them well enough to be beneficial.
jordangp
Post Thu Jul 19, 2012 12:07 am
Completely agree, they are an ass to design.
RicME85
Post Thu Jul 19, 2012 1:38 am
I've been scouring the internet for a tutorial on designing even something remotely close to those louvres and have drawn a blank! It'd be good if we had an F1technical member that knew how to do it and could do a tut!
krisfx
Next
Return to Engineering projects
Who is online
Users browsing this forum: No registered users and 1 guest
