Ferrari F2012
Post Wed Aug 08, 2012 4:28 pm
beelsebob wrote:Yes, it must "comprise only one component that must be symmetrically arranged about the car centre line with a minimum width of 708mm."
Thank you very much sir
fynrd1
Post Wed Aug 08, 2012 6:05 pm
maybe one of those 'interesting solutions' at Spa , that Fry mentioned , will be banned gurney flap on RW from 2011. :lol:
radosav
Post Wed Aug 08, 2012 6:17 pm
beelsebob wrote:
fynrd1 wrote:Is it allowed by the rules to bypass the hydraulicsystem for the DRS? By adding an extra actuator? I think i got an excellent and very controversial idea..
No, the aero parts may only be moved by the FIA provided actuator and that may only be controlled by the FIA provided McLaren ECU.
Are you sure the actuator is a spec piece. It wasn't last year, as I remember Ferrari switched between electrical acuation and a Moog hydro piece.
Pierce89
Post Wed Aug 08, 2012 6:58 pm
superdread wrote:What would be truly great are materials that have exotic thermal expansion behaviour (e.g. helix-fibers in a viscous resin => very high thermal expansion of the fibers (I don't know if such technologies exist but am pretty sure they could)). While heating (exhaust or cooling water) they could expand the diffuser, or make the floor bow down in certain areas (when coupled with a layer of non-expanding CFCs) and break bodywork rules only when the car is running hot (i.e. whenever a FIA official can't measure the car).
That would be highly experimental though, and banned within seconds.
if you can use such material then i thought it would be great but alas FIA mandate some material and govern which types of material you can use for your car and also sometimes limit the use of some material at different area of the car. Such as use of Titanium is restricted in some area of the car caz they can give u extra strength without putting a lot of weight, which in turns help weight distribution of the car.
So no use of such exotic thermal expansion material are permitted by the FIA...... :(
Formula One is a game.............. but not any ordinary game for me
F1.Ru
Post Wed Aug 08, 2012 8:27 pm
F1.Ru wrote:if you can use such material then i thought it would be great but alas FIA mandate some material and govern which types of material you can use for your car and also sometimes limit the use of some material at different area of the car. Such as use of Titanium is restricted in some area of the car caz they can give u extra strength without putting a lot of weight, which in turns help weight distribution of the car.
Yes they do, but this is the FIA, a worldwide authority in using foresight to make simple and loophole-free rules. They just regulate the ingredients of a material and not its structure, so some sort of micro-structured material would not be regulated (they couldn't enforce such a ban effectively).
Micro-structured materials are still in basic research state and F1 is too cost-efficient and wimpy to promote such novel technology.
superdread
Post Fri Aug 10, 2012 4:04 pm
I always thought something similar would be ideal to make your intake restrictor out of for Le Mans and WRC....
Post Fri Aug 10, 2012 6:24 pm
I think they are supplied by the ACO/FIA.
superdread
Post Mon Aug 13, 2012 1:58 am
Spotted this on Formulatechandart
To me the nose vane update for Hungary could be a pre cursor for a slightly larger upgrade for SPA?
Comparing to Massa' Setup:
I spotted this as well...
Tested in Mugello but never raced....interesting...notice on the beam wing a similar air vent/scoop to what Lotus has been Testing?
Gilles Villeneuve
Hail22
Post Mon Aug 13, 2012 2:28 am
Hail22 wrote:Spotted this on Formulatechandart
The text accompanying the vanes does convey, that Massa's is the new one, and the small vanes of Alonso look rather manky.
That middle section has nothing to do with what Lotus is using, the thing beneath it is the rear crash structure not a duct.
superdread
Post Mon Aug 13, 2012 3:52 am
I'm referring to the upper semi oval above the crash structure, you can clearly size a tiny gap...What I'm trying to say is that small slit/cut could be an aiding tool to break up the rear drag?
Gilles Villeneuve
Hail22
Post Mon Aug 13, 2012 8:50 am
Ah no, you're right – it's not a spec part, no idea why I thought it was.
beelsebob
Post Mon Aug 13, 2012 1:11 pm
Hail22 wrote:I'm referring to the upper semi oval above the crash structure, you can clearly size a tiny gap...What I'm trying to say is that small slit/cut could be an aiding tool to break up the rear drag?
What is "breaking up drag"?
Anyway, it looks rather like a replacement for the 15cm wing, in that it uses the 15cm rule to have the middle section of the beam wing produce a little bit more downforce.
superdread
Post Mon Aug 13, 2012 2:40 pm
What is the purpose of the different "v" shaped cut outs (sometimes one of them, sometimes two of them, why not three?) on the top edge of the rear wing?
Secondly, do they correspond or have anything to do with what's going on with the front wing? Are there patterns between the two?
Chuckjr
Post Mon Aug 13, 2012 3:17 pm
Chuckjr wrote:What is the purpose of the different "v" shaped cut outs (sometimes one of them, sometimes two of them, why not three?) on the top edge of the rear wing?
As luck would have it, I just recently learned about this.
The cutouts on the rear-wing flap reduce induced drag. They do so by "splitting" the upwash from (EDIT: from, as in, produced by) the wing so that its interaction with oncoming flow is minimized, which cuts drag.
Visualize two "gaps" in the air flowing through the Trefftz Plane above, which is a constant theoretical area behind the car and perpendicular to the its wake everywhere there is wake. Like a "stalking wall," it's a representation of the air the car just passed through. The cutouts reduce the amount of wake that has to "break through" this wall.
And although the front wing has an aerodynamic effect on literally every part of the car downstream from it, I don't necessarily think the new front wing and the V-shaped cutouts are significantly linked here.
bhallg2k
Post Mon Aug 13, 2012 5:06 pm
bhallg2k wrote:They do so by "splitting" the upwash from the wing so that its interaction with oncoming flow is minimized....
How do you physically 'split' the upwash from the wing?
Brian
hardingfv32
PreviousNext
Return to Formula One cars
Who is online
Users browsing this forum: CCBot [Bot], gavingav1, Google Adsense [Bot] and 11 guests
