xpensive
xpensive
214
Re: A shameless image thread for the enginephiles
xpensive
xpensive
214
The Corvette Falconer V12;
xpensive
xpensive
214
The only image of the never raced Ford Cosworth 3.5 V12 I could find, anyone?
Belatti
Belatti
33
Ford Weslake V12?
xpensive
xpensive
214
No, the Weslake V12 was almost 20 years earlier, this was built by Cosworth, but images are scarce.
strad
117
can't blow it up anymore
Sir Stirling Moss
xpensive wrote:The only image of the never raced Ford Cosworth 3.5 V12 I could find, anyone?
http://www.research-racing.de/gpx225.jpg
Seems like a early 90's engine. Could be a McLaren (test)thing after their tests with a (I believe) Lambo V12?
xpensive
xpensive
214
strad wrote:can't blow it up anymore
http://www.stradsplace.com/photos/Cosworth%20V12.png
That is the Neotech V12;
Another promising engine was designed in Austria in 1990. The Neotech V12 was however never used in any GP car. The 70 degree V12 design was drawing some interest from several GP teams but ultimately it never reached Formula One. It was tested in the back of a Brun Porsche 962 in 1990 but quickly disappeared from the scene.
xpensive
xpensive
214
The Renault 111 degree V10;
strad
117
:oops: :oops: :oops: :oops:
Sir Stirling Moss
xpensive
xpensive
214
This is so insane, a turboed 550 Maranello!
dren
226
Those almost look like superchargers, must be casing around the turbines. Either way that's pretty wild.
Honda!
countersteer
countersteer
DKW SS/UL Split Piston supercharged two stroke. A 5 piston, twin cylinder....
"For larger capacity classes a twin cylinder version of the UL was developed, and these motors were available in 350, 500, 600 and 700cc displacements, with the three latter capacities (some with multiple Ladepumpe pistons) reserved for sidecar racing. Unlike the ULe and ULd 250, the Ladepumpe was once again moved to the 180 degree position and driven off the main crankshaft with a pair of conrods. Thus these “twins” had five pistons: four 39.5mm items, plus the 100mm supercharging piston, all held together around a common crankshaft by six conrods. The cylinder block had the appearance of a square-four, and were distinguished from the 250s by their finned water jackets and the 180 degree placement of their Ladepumpe cylinders. A SS 350, which was virtually identical to the works UL machines, was offered to the public and sold in limited numbers." - http://www.odd-bike.com/2014/02/dkw-sup ... e-fed.html
dren
226
Great read. I really liked this one:
It's #6. Opposed cylinders and a supercharger.
Honda!
wuzak
wuzak
445
