the clutch is at about 8minutes 56..I think it was 8:50 something.
https://www.youtube.com/watch?v=-VF0JwxQqcA
There is plenty of information on the F35 on line J.A.W.J.A.W. wrote:Yeah r-r, got any references to cite - that give cost, serviceability, TBO & etc, facts on that F-35 VTOL?
Are any of them actually operational yet?
Maybe Auto-Gyro will chime in here & opine that the F-35 makes F1 look sensible.. budget-wise..
& T-F present as paragons of well-sorted economical longevity - by comparison
To be fair, pretty much everything looks sensible next to the F-35 program.J.A.W. wrote: Maybe Auto-Gyro will chime in here & opine that the F-35 makes F1 look sensible.. budget-wise..
I posted that video on page 2. It's my go to video when explaining top fuel drag cars to non-drag racing fans.strad wrote:the clutch is at about 8minutes 56..I think it was 8:50 something.
The air-cooled carbon-carbon clutch used to drive the lift fan on the F-35B has been operational for quite a while now.J.A.W. wrote:Yeah r-r, got any references to cite - that give cost, serviceability, TBO & etc, facts on that F-35 VTOL?
The F-35B is a STOVL aircraft that rarely performs a vertical TO. It mostly performs a short TO when carrying a payload, and performs a vertical landing after deploying the payload and expending most of its fuel.autogyro wrote:Hi riff raff, like to explain why the F35B is limited to 9 VTOL operations before engine rebuild?
Riff_raff. I have always wondered. why didn't they use carbon fibre for the drive shaft tube and housing? To save weight I thought they would have implemented more composites in that area.riff_raff wrote:The F-35B is a STOVL aircraft that rarely performs a vertical TO. It mostly performs a short TO when carrying a payload, and performs a vertical landing after deploying the payload and expending most of its fuel.autogyro wrote:Hi riff raff, like to explain why the F35B is limited to 9 VTOL operations before engine rebuild?
The F135 engine used on the F-35B does not require an overhaul after just 9 vertical landings. In fact the main reason the F-35B uses a shaft driven lift fan is because it is far more efficient at producing lift than the ducted compressor air system used by the Rolls-Royce Pegasus engine on the Harrier. The Pegasus engine needed to use compressor water injection to keep the engine from overheating when performing a vertical landing, and there was only enough water supply for about 90 seconds of vertical flight during a landing.
I know some of the engineers at Allison/R-R that worked on the F-35B clutch and lift fan design. The clutch has been qual tested for 2X the 400 engagement cycles required by the model spec. And so has the F135 engine power turbine and drivetrain connected to it.
There would be absolutely no point.Riff_raff. I have always wondered. why didn't they use carbon fibre for the drive shaft tube and housing? To save weight I thought they would have implemented more composites in that area.
If those components are steel alloys there would be considerable weight saving in a carbon fibre alternative as you say. Performance benefit/Cost ratio is always a factor. Torsional rigidity is another - driveshafts are often designed torsionally soft (quill shaft) to absorb torsional vibrations. The smaller diameter steel shaft would be better suited for quill shaft design.PlatinumZealot wrote:Riff_raff. I have always wondered. why didn't they use carbon fibre for the drive shaft tube and housing? To save weight I thought they would have implemented more composites in that area.
PZ- The F-35B does use a composite driveshaft to power the lift fan.PlatinumZealot wrote: Riff_raff. I have always wondered. why didn't they use carbon fibre for the drive shaft tube and housing? To save weight I thought they would have implemented more composites in that area.
I know a challenge with Carbon fibre driveshafts had always been the interface of the spline which is steel to the actual composite, but that problem had been solved so the diamater is pretty much the same as steel ones. One disadvantage that I know still remains is that if the shaft has to be regularly checked for any damage.Shooty81 wrote:I guess, you will get a bigger Diameter with carbon fiber driveshafts. Even if it's lighter weight, it will hurt aerodynamics.gruntguru wrote:If those components are steel alloys there would be considerable weight saving in a carbon fibre alternative as you say. Performance benefit/Cost ratio is always a factor. Torsional rigidity is another - driveshafts are often designed torsionally soft (quill shaft) to absorb torsional vibrations. The smaller diameter steel shaft would be better suited for quill shaft design.PlatinumZealot wrote:Riff_raff. I have always wondered. why didn't they use carbon fibre for the drive shaft tube and housing? To save weight I thought they would have implemented more composites in that area.
With the steel driveshafts, load application is also a lot easier.
