2015 Monaco Grand Prix - 21-24 May
Vasconia
Re: 2015 Monaco Grand Prix - 21-24 May
Thre reliability of the Mercedes power units is simply incredible. Honda´s situation is far from being good but it seems that RB is going to be the first team to get a penalty.
SiLo
130
I feel like Mercedes are really going to reap this advantage later in the year when other engine manufacturers might be turning engines down thinking more of reliability than performance.
Felipe Baby!
Andres125sx
I dont´t think Honda´s situation currently is that bad, reliability wise. Yes the start of the season was terrible, but lately they have had no big problems. A plastic film blocking brake ventilation can´t be considered a reliability issue. Button´s problem OTOH could, but that nust be electronics related that ruined driveability of his car, and that´s not as worrying as an engine breaking apart
Maybe I´m a bit too optimistic, but after watching Magnusen´s engine throwing pieces all around the track in Melbourne after qualifying last (no perfomance and no reliability) I think situation has improved very very much, now they qualify on Q2, we´ll see if Q3 is a real posibility, and they usually finish the races
As you say their situation is very similar to Renault, and Renault is on his second season with this engine so considering circumstances, I´d say Renault situation right now is much worse than Honda. Honda has the excuse of a new concept and his very first season, Renault don´t have any of the two but their situation is similar if not worse
Vasconia
Yes, Honda´s situation has improved in the last races though they know that they will face several penalites during the second half of the race. But better in this season than in 2016.
Renault situation is very bad but is worse with RB, I dont know why but RB has bigger problems than the others teams. Perhaps its chasis is specially hard with the weak Renault power unit.
BanMeToo wrote:
turbof1 wrote:
PlatinumZealot wrote:Merhi crash
http://www.gfycat.com/AgedTheseBaiji
That looks really bizarre. after he hits the barrier a first time he almost was standing still. Then suddenly he accelerates again, obvious to see what the amount of wheelspin accompagnied, which causes him to hit the barrier again. Looks like glitch in his car or something.
I disagree. He is definitely not moving slowly after the first hit - you are being tricked by the extreme zoom level of the camera. Totally normal crash. What you call 'accelerating again' is in fact Merhi letting off the brakes. The tires stop sliding when he does that and vector the car in the direction they are facing.
When a camera is zoomed in so far like this it is way easier to see something move left or right than tell whether it is coming toward or away from you.
There's wheelspin involved. That can't be explained by just letting the brakes go. It does step when he presses the brake pedal again. Looks to me like a software glitch.
FW17
168
Is that a nose cone write off or can it be salvaged?
F1NAC
163
WilliamsF1 wrote:Is that a nose cone write off or can it be salvaged?
Write off possibly because it is damaged at the tip od the cone
The tip might be detachable.
f1316
f1316
78
It's interesting to be going into FP3 with so little idea of what to expect.
I'm sure this will be greeted with shouts of "Hamilton is clearly going to demolish everyone/Mercedes has a lock on destroying the world with its little finger" - and that may very well be true - but we really haven't seen any representative running and none on the super soft which will be used for quali.
I have a feeling it may very well be a Singapore 2014 type situation where the extra grip afforded by the super soft brings everyone a lot closer and, whilst I still think Merc and mostly likely Hamilton will get pole, I'd put some money on top 5 being covered by less than .5 of a second.
Andres125sx
turbof1 wrote:There's wheelspin involved. That can't be explained by just letting the brakes go.
Yes it can. I´ve watched it several times, do this, watch it again, but intead of looking only at the rear tires, try to look at both the front and rear wheel at the same time....
They do exactly the same, no difference, same spinning rate. Actually front tires start spinning a bit sooner than rear ones, what I really don´t understand since brake bias always put more pressure on front tires :?: but anycase it´s clear there´s not throttle involved
After hitting the barrier first time he must think he could recover the control of the car and release the brakes, so instead of sliding with the four wheels locked it start rolling, and since the car was facing the barrier he hit it again
SiLo
130
f1316 wrote:It's interesting to be going into FP3 with so little idea of what to expect.
If the top 5 are covered by less than half a second I'll buy you a six pack of beer.
Felipe Baby!
Andres125sx
Probably not even top 3
SectorOne
Ferrari and down i expect a very tight qualifying. Mercedes will probably have a bit of a gap.
If it's dry, the pole time is going to be high to mid 14's, we really haven't seen anything yet.
f1316
f1316
78
Awesome. I'll have some sculpin ipas ;)
Well, it'll be interesting. I was going to say top 4 - so Mercs and Ferraris - but wanted to open up the possibility of someone doing something special.
But if we look at 2014, top 4 were basically .5 apart - Vettel just a shade over 5 tenths back. Top 5 were covered by about .7.
People on this forum - for reasons that escape me - seem to want to believe that the gap this year is bigger than last but I see no reason to believe that. Vettel has come out today to say he feels Ferrari has no slow corner problems, just an bad weekend in Spain, and I suspect that the stark differences in tyre usage between the two teams that has been in their DNA for years (Merc heat their's up quickly, Ferrari struggle to do so - been that way ever since Pirellis cam in) will be somewhat negated by the super softs.
Again, Kimi was fastest on super softs in Q2 in Singapore and it was noticeable how much those tyres transformed the car. The 2015 car is undoubtedly better in every way and, whilst my above prediction may, I'll admit, be an optimistic stretch, I am quite confident at least one Ferrari will be well within .5.
Let's see :)
