Scuderia Ferrari SF70H
Re: Scuderia Ferrari SF70H
Selvariabell wrote:
14 Apr 2017, 17:17
wesley123 wrote:
14 Apr 2017, 10:37
Selvariabell wrote:
13 Apr 2017, 18:18
although I am concerned on its sensitivity to dirty air.
Because?
More complex shape and more slots meant it is designed with clean air in mind. And more finer Aero details means more sensitivity to dirty air.
I don't think a complex shape or anything automatically means it's more sensitive.
Every car is designed to be as quick as possible, and thus are per definition designed to run in clean air.
The slots are there to reduce pitch sensitivity, and in effect allows a higher Angle of attack
Fer.Fan
Fer.Fan
ScrewCaptain27 wrote:
14 Apr 2017, 14:46
Finally a shot of the PU:
https://uploads.tapatalk-cdn.com/201704 ... c76825.jpg
Look at Ferrari PU, compared to MB. What a mess but it seems to work...
ScrewCaptain27
577
Fer.Fan wrote:
15 Apr 2017, 07:43
14 Apr 2017, 14:46
http://uploads.tapatalk-cdn.com/2017041 ... c76825.jpg
https://imgr1.auto-motor-und-sport.de/M ... 065483.jpg
It looks messy because it is being taken out of the car, while the Mercedes one is fully assembled.
- Serj Tankian
Dino Scuderia
Dino Scuderia
and there are the radiators covering the Merc while the Ferrari ones are off as well
TEHNOS
mani517
mani517
I'm not a very technical person, so, struggling to understand Pat Symonds' point of view about the flexing floor flap. He says "it isn't a cheat or anything like that", but, he also says "it isn't legal as it stands, IMO".
Rules don't allow a closed section and it isn't a closed section... so, why would he say it isn't legal? Can someone help me understand his opinion?
basti313
basti313
25
mani517 wrote:
17 Apr 2017, 16:19
I think the flexibility is the problem, not the slot.
But there are two problems and because of them no one really cares:
- It draw our attention when it was wobbling around. But it should not wobble, it can not do anything good for the aero when it wobbles up and down like mad. At this point it was simply broken.
- Merc is running a very similar flap. For others I did not check it. But I do not think Ferrari has found the holy grail with its cut in the floor, this is a rather standard piece in F1 and is on the cars since 5 years now. I think RedBull started this cutting.
Don`t russel the hamster!
mani517
mani517
basti313 wrote:
17 Apr 2017, 16:25
mani517 wrote:
17 Apr 2017, 16:19
Thanks for the response. May be, the length of this cantilever flap is making it flex a lot more than intended. Then again, if the intention is just to bleed the high pressure air from underneath the floor and flexing is counter-productive, it can't be too hard to fix -- unless, they don't want to change the shape of the flap or the material for some specific reason.
[edited] the more I think about it, Pat's point about the shape of the flap makes good sense. A slot running at an angle to the spine of the car is going to bleed a lot more air than the one that runs parallel to the spine of the car (like Merc's flap). So, may be, the flexing is the by-product of the length and shape of the flap & volume of air it bleeds from underneath the floor.
bill shoe
bill shoe
151
Fer.Fan wrote:
15 Apr 2017, 07:43
Wow, the installation drawing for the Ferrari engine must have 273 details and notes, but the installation drawing for the Mercedes engine probably just has one note: "Install this engine. It makes the car go. We have determined the optimal situation for championship points. Just install the engine."
.poz
.poz
43
basti313 wrote:
17 Apr 2017, 16:25
I think they fixed it
ScrewCaptain27
577
Via Racecar Engineering:
- Serj Tankian
.poz
.poz
43
.poz wrote:
18 Apr 2017, 11:18
basti313 wrote:
17 Apr 2017, 16:25
Piola confirm they fixed it with a metal plate embedded in the carbon fiber
