McLaren MCL32 Honda
Re: McLaren MCL32 Honda
Feel free to open a new Thread for the Nature vs. CFD Discussion, but please don't discuss it in this Thread.
ScrewCaptain27
577
FW detail, via AMuS:
- Serj Tankian
Via AMuS and @SokolimOkiem
Looks like there isn't a distinct outwash tunnel but rather it tapers along the width of the wing. Interesting, possibly a development item.
bill shoe
151
godlameroso wrote:
17 Oct 2017, 19:25
Those bargeboard updates on the floor won't work unless the track temperatures and conditions are right. Geometry needs optimization, they have a lot of potential when they get the slot shape optimized. The new outer vertical fin in particular needs to be modified, the trailing bottom edge should be more inboard, and the top edge slightly more outboard. Change required is small, a fraction of a mm.
Agreed, absolutely!! And the new structure will create slightly too much lateral vortex movement away from the floor during moderate yaw conditions. The trailing edge of the front wing should be moved forward by 0.5 mm to compensate. :D
bill shoe wrote:
20 Oct 2017, 03:45
godlameroso wrote:
17 Oct 2017, 19:25
Talking about the new front wing? Do you think they're racing that? They could, Red Bull has a similar lower plane on their wing.
bill shoe wrote:
20 Oct 2017, 03:45
:lol:
Sounds like the new engine won't be spec 4.0 going by what they were saying in practice, it's just a small update to the ICE itself, whereas spec 4 requires a new spec turbo/compressor.
FlowVis testing on the McLaren
Via @Albrodpul
Dipesh1995
104
Morteza wrote:
20 Oct 2017, 18:31
https://pbs.twimg.com/media/DMmEPqgX0AA4oZ9.jpg
Via @Albrodpul
Yep, there is one or two more inboard tip slot gaps presumably to further strengthen the Y250 vortex.
Dipesh1995 wrote:
20 Oct 2017, 18:51
Morteza wrote:
20 Oct 2017, 18:31
Via @Albrodpul
A closer look via @AlbertFabrega
Dipesh1995
104
Morteza wrote:
20 Oct 2017, 21:38
Dipesh1995 wrote:
20 Oct 2017, 18:51
Morteza wrote:
20 Oct 2017, 18:31
Via @Albrodpul
https://pbs.twimg.com/media/DMmtN20X4AALM4S.jpg
Looks like they’ve also changed the outboard part of the wing as well with additional slots on the foot plate (strengthening the edge vortex) as well as changing profile of the 3 winglets behind the cascade elements.
roon
412
Morteza wrote:
20 Oct 2017, 21:38
Dipesh1995 wrote:
20 Oct 2017, 18:51
Morteza wrote:
20 Oct 2017, 18:31
Via @Albrodpul
Nine elements--a new record?
hollus
I think even more than that by the end plate! If it can still be called a plate, that is.
Rivals, not enemies.
I like this new FW - hope it works well !!
