| Author | Message |
| scarbs | |
Professional![]() Joined: Wed Oct 08, 2003 8:47 am Posts: 780 Location: Hertfordshire, UK |
Silverstone Friday practice. It looks like Ferrari are going to run their static wheel fairings.
Lets get ready fo the protests.... Scarbs... Note: there is no wheel retention system on the hub, as its attached to the fairirng\wheelnut. The special wheel guns have bene seen in the pit too... ![]() |
| siskue2005 | |
Talent ![]() Joined: Fri May 11, 2007 8:50 pm Posts: 214 Location: India |
here is the wheel gun....can anyone explain, how it works?
| manchild | |
![]() Master ![]() Joined: Fri Jun 03, 2005 9:54 am Posts: 4542 |
The one with large plate is for wheels with CF cover - enabling mechanic to attach it to nut properly and perhaps it blows some compressed air into the rim to cool off discs during pit stop.
Over 123.000.000 animals killed daily, over 5.000.000 animals killed hourly, over 85.000 animals killed every minute. While you read this over 40.000 animals was killed. www.goveg.com |
| Sawtooth-spike | |
![]() Professional ![]() Joined: Fri Jan 28, 2005 2:33 pm Posts: 890 Location: essex |
Sorry got way to tempted,
They really should not give me days off! Ferrari new Cooling system (its really part of the braking system.... Honest!) and new nose ballast (Helps with the problems of following other cars)
I think Scarbs is right i think some teams might say something, but then again nobody did anything about the frezbes on the rear (well other than you manchild who was ready to go to war) |
| dp35 | |
Member![]() Joined: Tue Nov 14, 2006 11:58 pm Posts: 67 |
How are these wheel covers attached?
The only way I can think of is with a small shaft that would have to run through the center of the axle. This would not be possible on the rears. |
| RJC_pt | |
Rookie![]() Joined: Fri May 18, 2007 8:59 pm Posts: 27 Location: Braga, Portugal |
Well they could be fixed to the rim by a bearing and have the side that allways points down with a little balast, that would ensure it doesnt rotate.
| Downforce | |
Rookie ![]() Joined: Fri Feb 10, 2006 12:17 am Posts: 38 Location: Belgrade, Serbia |
This is the best picture that I was able to find...
| manchild | |
It there's a weight holding that plate in specific position than it is movable ballast because it is not firmly attached. If however it rotates than since it is asymmetrical it works as fan which is also i..... Over 123.000.000 animals killed daily, over 5.000.000 animals killed hourly, over 85.000 animals killed every minute. While you read this over 40.000 animals was killed. www.goveg.com Last edited by manchild on Sat Jul 07, 2007 4:06 pm, edited 1 time in total. |
| manchild | |
That front "ducting" is a two part system consisting from inner CF ring glued to rim while rim cover is attached to wheel nut. When replacing tyres rim cover goes off the wheel together with the nut and than gets back on wheel when nut is screwed.
Am I right? Has anyone seen tyre change detail? I guess that rim cover stays still on an additional bearing over the wheel nut while the only mystery remains what keeps rim cover in one position. The logic tells us that it is the weight but could it also be the aero shape from the inside (the thing we don't see?). Over 123.000.000 animals killed daily, over 5.000.000 animals killed hourly, over 85.000 animals killed every minute. While you read this over 40.000 animals was killed. www.goveg.com |
| checkered | |
Professional ![]() Joined: Fri Mar 02, 2007 1:32 pm Posts: 948 |
On the official F1
website the resident tech reporter Paolo Filisetti suggests that the 27 degree aperture in the cover directs airflow under the car (or helps direct more air under the car, there's a slight difference and I'm not entirely sure which way it is), increasing downforce. Therefore it has next to nothing to do with the rear tyre rim shields. No word on how it stays stationary, though. Keep your eyes open for the pitstops. |
| Tomba | |
Webmaster Joined: Mon Aug 19, 2002 5:32 pm Posts: 1729 Location: Belgium |
MC, here's my view on it: http://www.f1technical.net/development/95 I'm pretty convinced we have a combined wheelnut where one part rotates and the other doesn't. I don't think the weight would keep it in place anyway, and relying on it would also be illegal since it would be movable ballast. |
| rjsa | |
Talent![]() Joined: Fri Mar 02, 2007 2:01 am Posts: 222 |
It seems to me that the colored nut connects to wheel/brake cover. The white one seems glued to the cover and should fit deeper into the axle.
See above both nuts aligned. Below they are not. That would be the reason for the really long claws of the gun, taking care of two nuts. ![]() |
| kimi | |
Member![]() Joined: Fri Jul 06, 2007 6:19 pm Posts: 109 Location: india |
this is an indigenious concept 2 cool d red hot carbon fibre disks after heavy breakin.the 27 degree aperture in d lower part of d rim allows d hot air 4m d brakes 2 fly underneath d car and in dat way increasin d aero balance of car.
2 know how it works refer 2 d link below http://www.f1technical.net/development/95 we still havnt seen its use in live racin.lets wait 4 d british gp 2 catch up wid d pit stop. |
| Blake | |
Newbie Joined: Sun Jul 08, 2007 8:16 am Posts: 1 Location: NSW, Australia |
For anyone wondering why Ferrari’s aero developments around the wheels are considered legal (I know I was when Ferrari introduced the small winglet behind the front brake ducts) then you should read article 11.4 of the technical regulations, as well as article 3.15.
Thus, anything in the invisible box created by the measurements in article 11.4 are not bound by the regulations in article 3.15 about aerodynamic influence. This means that (in theory) any aero in that area can:
| Apex | |
Member![]() Joined: Thu Jul 07, 2005 11:54 pm Posts: 114 |
This has nothing to do with brake cooling or rear downforce.... its all a ploy that MS has implemented so that the Ferrari drivers can rub wheels with out the cars flipping over
| Similar topics | Forum | Replies | Views | Last post | |
| Ferrari engineer to McLaren | General chat | 10 |
5532 |
by axle on Thu Jul 31, 2008 2:08 pm |
| Ferrari's clutchless transmission | Engine, transmission and controls | 12 |
5199 |
by hecti on Tue Mar 31, 2009 8:12 pm |
| Ferrari Technical preparation for Monza | Engine, transmission and controls | 5 |
3554 |
by DaveKillens on Thu Mar 31, 2005 6:55 pm |
| Ferrari tyre secret? 1, 2, 3 | Aerodynamics, chassis and tyres | 43 |
13577 |
by ajinkya14 on Thu Aug 20, 2009 4:28 pm |
| Ferrari F1-2002 | Engine, transmission and controls | 1 |
1824 |
by Tomba on Sat Mar 08, 2003 6:54 pm |
Users browsing this forum: No registered users and 1 guest
