I have been thinking how the fan will be controlled. Of course the fan will be standard FIA equipment. The maximum speed is regulated. The fan is only enabled when you are within 1 second of the driver in front. It is up to the driver to activate the fan or not. This will surely eliminate any down-force loss. As for stones and debris... The fan is not that powerful guys... It won't be adding any more upwash than the diffuser makes already... remember it is roughly the same down-force you want to get back.
It is not exaclty dead. I have been getting some inbox notices from it as of late, So i suppose people are still reading it. I think the anticipation for the 2017 regs to be finalized draws people to it.
I think using a fan and reducing the wings is a pretty decent idea. That would reduce the effects of "dirty air" and enable cars to follow each other a lot closer.
One thing about wanting racing to be "natural", we all enjoy one of the most technologically advanced -ie farthest from natural- racing series (I dare say Le Mans is at least on par). If we wanted to keep things natural, we should ask the teams to catch wild horses (none of that thorough bread thing) and race them.
Skeptical scrutiny is the means, in both science and religion, by which deep thoughts can be winnowed from deep nonsense. Carl Sagan
About that "...to catch wild horses..." idea.. is it really sporting.. & who'd watch that.. anyhow?
As for the technical fan-induced down-force matter, & a return to F1..
well, "Dyson" the pretentious/expensive-gimmickry vacuum/blower-fan mob, would be in, surely?
A fan is the least good idea to create downforce going. There was a reason why it was banned because it was bloody dangerous to other competitors and spectators in the event of a crash which sent supersonic debris into the air. If you've watched motor racing long enough you know that the maxim, 'if it can happen it will happen', to be a truism.
A much better solution would be to allow variable floor geometry i.e. a controllable flexi-floor with active suspension. If the rules allowed it the teams would be producing ground effect monsters that dispensed with near enough all wings except for some skinny things used for trimming out balance.
The answer to closer racing and more exciting races are not gimmicks like fans or DRS but a fundamental rethink about downforce generation and getting cars closer in the corners to make use of the leading car's slipstream which was my childhood's DRS.
Actually, the answer to close racing etc. is a fully specified car i.e spec series. That way the car can be designed with that goal in mind and the teams can't design the cars which prevents them from following closely.
Either that or low downforce.
If you let the teams design the aero you will end up with optimised cars that don't follow well.
Thinking further on the problem of optimization. One way would be to require the teams to demonstrate to the FIA that their design can follow. Make them show downforce figures and distribution in free air, behind an identical car and behind an FIA test object. The design must be able to maintain a given % of it's free air downforce and, crucially, it must maintain its downforce distribution i.e. balance.
The teams can optimise to their hearts' content so long as the design still follows another.
What about racing in a total vacuum where aerodynamic drag doesn't exist?
