I'm literally working on that as we speak... 4 years of effort has me close to an aluminum electrospinning 3d printer at 2nm resolution. Printing engine components is exactly why I started designing and building it.
Would 200 Tons of vacuum make the dowel 5mm across? The vacuum I use is 10^-8 mbar. I dont know how to calc the force from it. I could see a spherical dimple in the end of the stud if increasing surface area for the vacuum to act upon has any positive clamping effect, as well as the dowel seat having a spherical bottom. I guess that if you machined it correctly, as the 2 pieces are put together, it would leave a perfectly spherical chamber in the dowel hole that would contain a deep Torr vacuum.Greg Locock wrote: ↑13 Jan 2018, 01:39Cylinder head bolts have a tensile strength of about 1500 MPa. So a 12mm bolt (WAG) has about 75mm^2 of usable section, that is, it exerts an axial force of about 1500E6*75E-6 N, about 10 tons, of which perhaps 20% is actual fluctuating load, so call it 2 tons - the rest is friction and preload. 2 tons of vacuum would need an area of 1/5 of a square metre, ie a dowel 500 mm across. To replace one bolt.
Is there a reason that you say that? I don't see any correlating factors in this thread to support such a statement.
From my reading and understanding, the pulling force of a vacuum has surface area interaction. There is a point that the vacuum will start pulling apart the surface (sublimation). That was the part that I thought might be the most difficult, as if you lowered the contained vacuum enough, the heat cycle of the engine might literally vaporize the material in the cavity.
Why would I take it into space?
One of the latter, unused NA engines from BMW had the heads and block cast as one. They did get around the machining limitations. But head gaskets and bolts don't seem problematic for F1, so it's likely not worth the extra attention.Big Tea wrote: ↑13 Jan 2018, 02:04The original point, that of not having head bolts etc is still valid though isn't it?
How come, with modern techniques, F1 engines still have a separate head?
Is it due to the access to the valve area, and setting up clearance, or is there a good reason for having a lid that comes off?
The depth of the cylinder of a F1 engine is small, so I doubt it would be due to not having tooling or access angles to make the valve seats etc, so other than maybe casting in cooling passageways, is there a good reason other than tradition?
