Zandvoort
Post Reply
TEHNOS
Re: Zandvoort
But, suppose, one stand is gonna sit on top of oval dune.
https://t.co/43YeEH0Jox
Another, since they are leveling the dune, on the T11- T12 back straight.
They are moving Hugenholtz inside, for the banking itself and to make space in the paddock,
not sure, whether there is enough space for the stands.
Another group of stands is supposed to be in the inner track area opposite T13 and towards T14.
Kind of like situation before the banking of the Luyendijk and Hugenholtz were revealed.
Andres125sx
Re: Zandvoort
Big Tea wrote:
18 Dec 2019, 18:07
Are they not putting a large grand stand around the outside of that curve? Missed opportunity if not.
I don´t think that´s a good idea. Cars will corner at a very high speed there, so a big runoff area is mandatory. The stand would need to be far away, or it would be dangerous
That´s assuming the runoff area will continue the banking angle so any car going out of the corner will not jump. Otherwise it will be very dangerous
Re: Zandvoort
Zandvoort denies final corner banking will cause tyre problems
But Lammers is not expecting any such repeat [as in 2005 Indianapolis Motor Speedway] when F1 returns to Zandvoort with Pirelli rubber in 2020.
“I don't expect any issues with the tyres,” he said. “There are two reasons for that. First of all, the corner in Indianapolis is way longer than this one. So the overall tyre load was much heavier there.
"And second, the corners in Indianapolis have some kind of linear banking. Over here we have a progressive banking, almost comparable to a bobsleigh track.
“We talked to Pirelli as well. Basically from the first moment we thought of creating a banked corner in Zandvoort. We speak to them on a daily basis and share all the updates and information we have.”
https://www.gptoday.net/en/news/f1/2531 ... e-problems
TEHNOS
Re: Zandvoort
Re: Zandvoort
They are very lucky with the mild weather.
Normally it is much colder now and it can start freezing.
They work with at least 100 people a day from Volker Wessels,
to get the "small adjustments" :D to the circuit ready in time.
Sieper
73
Re: Zandvoort
It does seem a bit like a race against the clock right! These are no small changes by any stretch of imagination. Many corners overhauled, track widened, access tunnels under the track, resculpting the entire area. We indeed are lucky with this weather, it is not cold at all.
Then next year new grandstands and paddock?
TEHNOS
Re: Zandvoort
Radical changes to Circuit Zandvoort
https://www.tracksidelegends.com/articl ... -zandvoort
Since the first visit to track by Formula One Management in 2017, followed up by a visit of the late Charlie Whiting in 2018 who said the track has a good shape and would be a perfect fit for F1, a lot has changed. From lawsuits about the impact on the surrounding nature, till the mobility plan and concerns about the Pirelli tires in banked corners. It seems the organizers of the Dutch GP have thought about every aspect in advance in supreme detail, hence the preparations already starting 5(!) years ago. And they made this business case work without any direct government funding.
TEHNOS
Re: Zandvoort
Documents, maps, details :D
https://t.co/zXwdTgfNmf
TEHNOS
Re: Zandvoort
Pit exit seems to go all the way through Tarzan on separate inside line =D>
TEHNOS
Re: Zandvoort
96200 seated places plus existing grandstand and general admission. Nicely packed. =D>
Juzh
161
Re: Zandvoort
20 Dec 2019, 10:19
At least they're taking it seriously. I was sceptical at first will all the lawsuits if the entire thing would be cancelled, but it seems they've taken care of everything, even without public funding.
Juzh
161
Re: Zandvoort
TEHNOS wrote:
20 Dec 2019, 21:15
Looking at this article, the following caught my eye:
The Dutch equivalent of ‘Eau Rouge, called the ‘Scheivlak’, will still be surrounded by gravel. If you make a mistake there, you’re lost.
=D> =D> I just hope it's not easy flatout with next year's cars.
Re: Zandvoort
Juzh wrote:
22 Dec 2019, 15:13
20 Dec 2019, 10:19
First they said that only a few small adjustments were needed, but a lot had to be done.
They are indeed doing it thoroughly now! They leave nothing to chance.
TEHNOS
Re: Zandvoort
Mammoet cranes are now being used for the renovation of the track, but when the track is open it will be used for the removal and lifting of heavy objects (race cars) as official event supplier of the DutchGP.
Post Reply
