Python tool to extract data from F1 app
Xwang
Xwang
29
Hi to all,
I've found this tool for extracting data from the F1 official app:
https://github.com/KurtMoran/F1-Data-Extractor
Does anyone use it or similar one to get data like speed graphs and so one?
I'm thinking about giving it a try to analyse F1 testing and races.
It seems that the TV access subscription needed but it is only 27€ a year.
PS I do not know how to record the video of the app and if the replay option is available only on the app or also from the web access
nzjrs
Re: Python tool to extract data from F1 app
I do the same thing, but found it wasn't necessary to train a custom tessaract detector for the F1 font.
Zynerji
110
Does the app actually have an API?
Oehrly
Zynerji wrote:
23 Feb 2020, 20:35
Pretty sure, but it's not going to be public and certainly not documented.
It probably can be reverse engineered, but I would guess that all requests are encrypted. You should be able to decrypt and read the traffic anyways but the whole project would take quite some time.
Oehrly
OK, did a quick check on my phone
So as I guessed. It has an Api and requests are send over https.
I could only check Events because I don't have an account. But I'm sure it's going to be the same for telemetry.
nzjrs
Is the telemetry drawn client-side?
Xwang
Xwang
29
Interesting, but how to use it to save and extract telemetry data?
Zynerji
110
Not sure yet, but there is an API in there. Might be the bootstrap needed to pull this info directly.
Oehrly
I quickly read through the code. I don't think you can get telemetry with it. Doesn't look like it's implemented. It is called "Minimal API" after all.
If I finally decide on getting an F1 TV subscription and if I have some time, I might take a closer look at it. And maybe I'll try and write a more extensive API wrapper in Python.
Juzh
161
Not too long ago there was a reddit thread where a user was explaining in detail how to scrape all data directly off of websocket, no OCR required, but I think it's only possible for live sessions (don't quote me on that). This way he managed to capture a bunch of data, but crucially I don't think speed traces are included.
For those really interested I suggest reading the entire thread and author's past comments:
https://www.reddit.com/r/formula1/comme ... a_sectors/
Zynerji
110
Juzh wrote:
24 Feb 2020, 18:08
This API definitely seems more comprehensive... Awesome find!
https://github.com/Ax6/Fast-F1/tree/master/fastf1
Oehrly
So, I'm a bit confused currently. I've seen screenshots like this a few times now
https://i.imgur.com/gTMYIZc.jpg
Which app is that? Do I need F1TV Access/Pro to get that? And is it only available as live data or can you view it after a race? What about testing?
Juzh
161
Oehrly wrote:
25 Feb 2020, 16:49
You need F1TV access. It's available for all race weekend sessions (fps, quali, race) live and as a replay. It's only available live for testing, no replays.
Xwang
Xwang
29
Zynerji wrote:
24 Feb 2020, 18:34
Juzh wrote:
24 Feb 2020, 18:08
Using this API, I've managed to do this one
Which is the same as viewtopic.php?p=891389#p891389
The total length is different between the two pilot traces (about 2 meters) so I think the best way to handle that is to normalize the length of the lap to the circuit official length. Do you agree?
Moreover the minimum speed is at different lap position especially in the last turns, but maybe it is a symptom of an early chord point?
Leclerc lap starts at 6 m and ends at 5502.5 m (total lap length 5496.5 m).
Hamilton lap starts at 2.5 m and ends at 5505.5 (total lap length 5503.0 m).
The official track length is 5554 m.
According to you is it possible that on a qualifying lap to have such differences or is it given by telemetry approximation?
On the API documentation page there is the following warning:
Code: Select all
Absolute time is not super accurate. The moment a lap is logged is not always the same and there will be some jitter. At the moment lap time reference is synchronised on the sector time triggered with lowest latency. Expect an error of around ±10m when overlapping telemetry data of different laps.
I do not know if it applies to the above case too.
