https://gcaptain.com/project-to-test-fe ... k-carrier/AJI wrote: ↑Thu Nov 14, 2019 2:52 amMy nephew has a solution. Sails, that are made from solar panels, plus wind turbines and exercise bikes for the occupants!Big Tea wrote: ↑Thu Nov 14, 2019 12:14 amThey would produce all the time there is light, not just when the vehicle is moving. If it just adds a few % it could be worth while (depending on cost) especially as they seem to be developing light weight full spectrum units.Brake Horse Power wrote: ↑Thu Nov 14, 2019 12:04 am
Agree on that. I did a quick math on what would happen if you place solar cells on the containers of a large container vessel. Different case but I thought I concluded maybe you can have 4 megawatt peak..which seams a lot but it requires a lot more to replace the 100MW internal combustion engine
pic here of a truck decked out, but it is an advert of course
https://flisom.com
Maybe not so far off. They are also developing airships with solar wrapped around the envelope. Above the clouds so constant power.
