C8 Corvette
humble sabot
27
Re: C8 Corvette
there was a leak of some CAD/CAM drawings for the twin turbo they're supposed to put in this later and it's a DOHC. So they've got that going for them, which is nice
the four immutable forces:
static balance
dynamic balance
static imbalance
dynamic imbalance
flynfrog
Re: C8 Corvette
humble sabot wrote:
20 Jul 2019, 01:53
I wonder if they will get the heads from a certain boat engine company.
https://www.mercuryracing.com/mercury-r ... te-engine/
roon
412
Re: C8 Corvette
digitalrurouni
Re: C8 Corvette
Wife says to get it and sell the Spyder. Also allowing me to get a Tesla at the same time lol as the daily. Might have to take her up on that offer but need to see this Vette in the flesh and try it out myself m I never buy a first year model anyway. Right now the car is incredibly appealing though it's not the prettiest. But show me a better bang for your buck in the mid engined category!
NL_Fer
82
Re: C8 Corvette
I didn’t say pushrods are better. But compare this engine to an Audi FSI V8 and the performance is the same. The technology is good enough for high performance road car.
And yes it has the benefit of lower cog and no 2000€ timing chain rebuilt needed. I was never impressed by American V8 till i saw a block for real in a project car. It was so small, still a 5L and power enough.
For the C8 is wished they kept high front fenders and smooth rear from previous Corvette’s. It would have made the car more recognizable.
Jolle
Re: C8 Corvette
The strange thing is, GM has got a high tech V8, the Blackwing, a 4.2l DOHC twin turbo from the Cadillac CT6.
RZS10
359
Re: C8 Corvette
i was bored
it's the front, rear and a modified C7 side slapped onto the new car
Re: C8 Corvette
RZS10 wrote:
20 Jul 2019, 16:08
i was bored
https://i.imgur.com/k9U1e9O.png
Please be more bored, that looks great :P
SmallSoldier
473
Re: C8 Corvette
Jolle wrote:The strange thing is, GM has got a high tech V8, the Blackwing, a 4.2l DOHC twin turbo from the Cadillac CT6.
That would have being interesting... Heat management could be an issue with Turbos on a mid engined car.
Jolle
Re: C8 Corvette
SmallSoldier wrote:
20 Jul 2019, 16:51
Just like the AMG 4.0 it’s a hot V, so all the heat is nicely contained within the engine, unlike the LT they use now where you have hot pipes on both sides
roon
412
Re: C8 Corvette
Where have I seen these headlights before?
Seem familiar...
Hmm...
N, no...
:o
strad
117
Re: C8 Corvette
By sticking with a pushrod engine the say they keep the weigh down lower. lower c/g.
Sir Stirling Moss
Maritimer
19
Re: C8 Corvette
Pushrod engines are lighter, smaller, and cheaper than anything with cams in the heads. Unless you absolutely need fine timing and lift control or lots of revs, DOHC just makes things heavy, bloated, and expensive.
Jolle
Re: C8 Corvette
strad wrote:
20 Jul 2019, 19:42
Compared to the same engine with DOHC, but the LT2 is quite high compared to what the other sports cars use. A LS2 is almost 80cm high while a modern v8 from a European constructor is below 70cm.
It's all ok to use old tech to save money and make a high performance mid engine car within reach for anybody who doesn't work at the stock market, but that's it. These are dinosaurs in car tech. To be fair, the engine from any other V8 mid engined car would probably cost more than the whole C8.
To make it a bit affordable in Europe a twin turbo V6 would be nice as a base model. With this engine it would probably cost as much as an Audi R8 or AMG GT (and close to the cheapest McLaren)
roon
412
Re: C8 Corvette
Jolle wrote:
20 Jul 2019, 20:01
...the LT2 is quite high compared to what the other sports cars use. A LS2 is almost 80cm high while a modern v8 from a European constructor is below 70cm.
Are you factoring in dry sump?
Also consider that even if the height is greater the CoG may not be. OHV rocker covers are lightweight but often tall. The 16 rockers and 16 upper portions of the pushrods should be lighter than 4 camshafts, 32 followers, and the upper portion of two timing chains. The intake manifold will be the highest part but this will be lighter than the hot-vee twin turbo manifold assembly used in those modern European V8s.
Post Reply
