Ferrari F2012
Owen.C93
Owen.C93
171
Re: Ferrari F2012
There might be a little bit. Looks like it's for a bit of damper cooling anyway since Ferrari route cooling through the acer ducts not through the gearbox like other teams.
Cacarella
Cacarella
Re: Ferrari F2012
hardingfv32 wrote:What makes you think any flow is going in this hole (yellow arrow) after rounding that bend in front of it. This going to be a low pressure zone. I also doubt there will be any useful flow for the red circled zone to utilize.
Brian
Given my limited knowledge of the subject I'd say that the yellow hole is one of two things (as are most holes on F1 cars);
1. An inlet
2. an Outlet
Based on the shape and position, I'd say it's an inlet. For what? I can only speculate that Ferrari has located some KERS capacitors in the rear floor a-la Red bull and this is aiding cooling.
Given my limited knowledge of aerodynamics I'd guess that this is a low pressure zone but there must be some flow going to that arrow. The low pressure may seem exaggerated because of the overhang of the acer duct but that is if you only take into account flow that is traveling over the top of the sidepods. There's obviously flow traveling around them as well so it's probably this air that is reaching it. If there was absolutely no air traveling in that area RedBull wouldn't have gone to the trouble of creating a side-pod 'bridge' to that area.
Cuky
65
Re: Ferrari F2012
My thoughts are that it is an access point for rear suspension adjustment. Given that it is in very low pressure zone it would not hurt them with drag really
Owen.C93
Owen.C93
171
Re: Ferrari F2012
Cuky wrote:My thoughts are that it is an access point for rear suspension adjustment. Given that it is in very low pressure zone it would not hurt them with drag really
They would cover it if it was. Even if you don't think it's draggy you have to consider debris.
Cacarella
Cacarella
Re: Ferrari F2012
Not sure if it's been pointed out or simply obvious to everyone else
(I swear I've read this thread from beginning to end)
But Fernando and Felipe seem to be using different mirrors.
Must be driver preference, no?
EDIT or perhaps Fernando's are worth eight tenths?
jaba.hut
Re: Ferrari F2012
It is different. It is obvious.
strad
117
Re: Ferrari F2012
The mirrors are not different or I'm blind,,,the stalks are different...and that would be to fit the driver.
Sir Stirling Moss
Re: Ferrari F2012
Hmmm.. interesting. Massa and Hamilton are the only drivers to have knowingly requested higher mirrors.
amouzouris
105
Re: Ferrari F2012
n smikle wrote:Hmmm.. interesting. Massa and Hamilton are the only drivers to have knowingly requested higher mirrors.
i wonder why that is!! ;p
Nando
Nando
Re: Ferrari F2012
Alonso sits lower, lower mirrors.
Crucial_Xtreme
Crucial_Xtreme
404
Re: Ferrari F2012
A couple of interesting shots here.
Check out the gurney flaps on the diffuser
The carbon piece seems to be gone. I thought originally it was a cooling exit, but not so much now.
xpensive
xpensive
214
Re: Ferrari F2012
Guess the Scuderia is waiting for another race to drop the big one, right Z and X2?
extrater
extrater
Re: Ferrari F2012
strad wrote:The mirrors are not different or I'm blind,,,the stalks are different...and that would be to fit the driver.
As Nando said, difference in driver position.
amouzouris
105
Re: Ferrari F2012
wow! there is a gurney flap on the gurney flap! :D
amouzouris
105
Re: Ferrari F2012
haha! that's right X!
