Red Bull RB8 Renault
hardingfv32
hardingfv32
32
Re: Red Bull RB8 Renault
mep wrote:The way to measure that is putting the car or engine on a dyno which I have never seen on an a GP. There is no sensor on the engine to measure torque directly as this is also not so simple to do.
I would say they know the torque before and after the clutch, and at each axle.
Brian
alogoc
alogoc
-10
Kate Walker ‏@F1Kate
Been told that post-race scrutineering could be a bit more interesting than usual this afternoon/evening. RBR throttle drama not done yet!!!
THE F2012!
THE CAR THAN WON 2012 WORLD F1 CHAMPIONSHIP WHIT A TILTED ENGINE!
hardingfv32
hardingfv32
32
Can someone please state the position of why 5.5.3 was breached? I do not understand what is wrong with changing the torque output in the mid rpm range as long as you comply with the current rules.
Brian
alogoc
alogoc
-10
Domenicali about RBR off-throttle; ‘ Tomorrow there will be a technical meeting and this will be discussed.’
THE F2012!
alogoc
alogoc
-10
At a selected rp/m range they retard the ignition timing but fuel is still at the same amount creating a powerful exhaust thrust but reducing horsepower. So on certain corners they will use gears that are taller but have their feet 100% on the floor. Basically what Red Bull has done is reversed the blown diffuser on the over run and moved it toward on acceleration.
how correct is this theory?
THE F2012!
jz11
jz11
19
for someone with access to leading car telemetry data it would be easy to see if this is the case, compare gear selection and accelerator pedal position between RB and other leading cars
but anyway this theory seems flawed because in that case the engine is running at lower rpm that it would normally do, thus you already lose all that air/fuel mass right there, I would guess that running lower gear than normal with the "low torque" mapping and throttle wide open you can't get more air into the engine at 15k rpm than you would using the "normal" mapping, "correct" throttle position and 16k rpm because of the higher gear you would select
It's probably the other way around - in the low speed corners where you would be spinning the rears in a lower gear, they've altered the mapping to allow the drive to get full throttle earlier and retarded the timing to control the power, thereby providing more exhaust flow.
I'm not sure why that would be a surprise however, it's a pretty standard mapping technique
hardingfv32
hardingfv32
32
alogoc wrote:At a selected rp/m range they retard the ignition timing but fuel is still at the same amount creating a powerful exhaust thrust but reducing horsepower. So on certain corners they will use gears that are taller but have their feet 100% on the floor. Basically what Red Bull has done is reversed the blown diffuser on the over run and moved it toward on acceleration.
Even after last years discussion, we have no science indicating what is required for best blowing results. Is it volume, temperature, etc. How much heat does the fuel in the exhaust system create? I would not use the words 'powerful exhaust thrust'.
Brian
bonjon1979
bonjon1979
30
PhillipM wrote:It's probably the other way around - in the low speed corners where you would be spinning the rears in a lower gear, they've altered the mapping to allow the drive to get full throttle earlier and retarded the timing to control the power, thereby providing more exhaust flow.
Is this not a form of traction control as well?
raymondu999
It's delaying the power - not actually reducing wheelspin.
失败者找理由,成功者找方法
mx_tifoso
mx_tifoso
But if it reduces wheelspin in the process, doesn't it technically make it traction control?
raymondu999
I think the key differentiating point here is whether or not it takes over in terms of traction or is just a help.
It would indeed help the driver to keep the traction in check. But if the driver were to wish it, he could still do a burnout on corner exit, which isn't the case with traction control.
失败者找理由,成功者找方法
mx_tifoso wrote:But if it reduces wheelspin in the process, doesn't it technically make it traction control?
Not really, just torque limiting, it has no feedback or sense of what traction the wheels have, and no input on whether the driver spins the rears up or not, it's just making the car easier to drive.
If it also happens to give blown exhausts because the throttle can be open much earlier, bonus.
alogoc
alogoc
-10
http://www.auto-motor-und-sport.de/form ... 47419.html
it's about traction after all hardingfv32!!! :D
THE F2012!
bhall
bhall
244
I've seen it termed "traction management," and I think that is a better way to phrase it. But it's just semantics as far as I'm concerned, because the net effects are similar.
