Mercedes AMG F1 W04
Post Reply
Nobody important
Re: Mercedes AMG F1 W04
Matt Somers wrote:It also isn't the same hole/slot it's just a bevel in the rims surface....
Ok thanks for the clarification.
Dreameagl
If you open the picture separately and then magnify you can clearly see there is a slot in the wheel. You can compare the same step in the rim on the front wheel where it is not open.
theformula
Check this out, mark hughes' article on the hungary tyres and mercedes: http://www1.skysports.com/formula-1/new ... y-for-more
Hamilton's blessed with an ability to make a car do pretty much anything he wants - Mark Hughes
Matt Somers
179
Nobody important wrote:New here but this is another picture for you. (The guy to the far right which the picture is trying to point out.)
This is at Bahrain the original poster said.
http://i.imgur.com/hSrakyC.jpg
I was talking about this image in my previous post... The article done by F1Talks I can confirm shows an aperture in the inner surface of the rear wheel as I have the full hi res images... The subject will be covered in my post race article for Pitpass...
tony77g
36
Contact:
Another Pic, GP Monaco saturday in Q3
SiLo
130
Venting heat from the wheel rim created by the brakes?
Felipe Baby!
rifrafs2kees
deleted
Matt Somers
179
I did some digging on this wheel aperture last night - http://somersf1.blogspot.co.uk/2013/07/ ... trick.html
timbo
111
Crazy idea, could it be that the outer rim and the inner part of the wheel are completely separated and are joined by some elastic material, which only serves to hold air?
emmepi27
141
Contact:
This is my personal idea of "cooling rims"
timbo
111
Ah, is the wheel black or it is just the shadow?
if it is indeed black and the "slot" was around Silverstone then your drawing makes sense.
emmepi27
141
Contact:
RX of rear tyres. I think that the air inlet on the brake fairing is just under the gap in the rim. So, my idea is that this solution are there to cool the tyre by a inner tube in the rim!
tony77g
36
Contact:
Seems to have solved the mystery, is not a fan
they say F1talks.pl, Craig Scaborough and Tobias Gruner
read Here:
http://www.f1talks.pl/2013/07/31/nie-po ... tura-opon/
emmepi27
141
Contact:
MIstery solved??? I don't think so. Everybody doesn't think so! According to Scarbs, "without seeing it for real we can't be 100% sure".
This photo is from SomersF1. I don't see a strip here; i see a groove...
nacho
emmepi27 wrote:MIstery solved??? I don't think so. Everybody doesn't think so! According to Scarbs, "without seeing it for real we can't be 100% sure".
http://1.bp.blogspot.com/-wYBKP3tPGT8/U ... larged.jpg
From there is surely looks like a wheel made from 3 parts! Or a groove with black coating. Are wheels allowed to be made from multiple parts? Could it really be that they made an elastic wheel to colld the inner wall.
Post Reply
