Caterham CT-05 Renault
ScrewCaptain27
538
Re: Caterham CT-05 Renault
ARB and wishbone mounting close-up (@KevTS):
- Serj Tankian
ScrewCaptain27
538
Images of the chassis being built (@KevTs):
- Serj Tankian
ScrewCaptain27
538
And here is some technical information about the chassis thicknesses and construction. Again I think this is the first time certain details have been shared about a modern F1 car. Thanks to Mr. Thomas.Image
- Serj Tankian
ScrewCaptain27
538
Airflow diagram with original spec nose (via @KevTs):
- Serj Tankian
bill shoe
bill shoe
247
Chassis diagram appears to show half of a monocoque that totals ~ 40 lbs. So is the complete monocoque ~ 80 lbs?
ScrewCaptain27
538
bill shoe wrote:Chassis diagram appears to show half of a monocoque that totals ~ 40 lbs. So is the complete monocoque ~ 80 lbs?
More or less that's what they usually weigh
- Serj Tankian
jjn9128
293
ScrewCaptain27 wrote:
Tue Aug 15, 2017 10:13 am
80lbs is 36kg. That seems on the low side to me. That diagram is just showing where the aluminium honeycomb is going to be positioned for FEA and manufacture. It excludes the weight of suspension and other mounting inserts, rohacell core, carbon weave and resin (sandwiched together in pre-preg), which depending on the number of layers will add significant weight. 70-80kg total would be more like it. The monocoque weight has been increasing in recent years due to improved penetration protection around the suspension arms.
EDIT: a quick google shows scarbs quoted 70kg back on 2006
#aerogandalf
bill shoe
bill shoe
247
jjn9128 wrote:
Tue Aug 15, 2017 11:11 am
Thanks, OK so the 80 lbs or 36 kgs is simply the weight of the aluminum honeycomb, not the weight of the overall monocoque. The overall weight would be ~ 70 kg or slightly more due to increased penetration protection, etc.
mycadcae
Aluminium Honeycomb vs Nomex Aramid Honeycomb...how?. F1 car can'not used nomex Aramid honeycomb?.
Regard,
Nik Wan, Mechanical Designer, CATIA V5/ Solidworks/Autodesk Inventor/ AutoCAD
jjn9128
293
bill shoe wrote:
Tue Aug 15, 2017 2:42 pm
I believe so. I also found that the Dallara DW12 monocoque is 81kg (or 179lbs) so close to 70kg for F1 seams reasonable.
#aerogandalf
mycadcae
source (via @KevTs):
Regard,
mycadcae
dero wrote:
Sun Oct 04, 2015 6:15 pm
torrent pretty please? :wink:
http://www.cutestpage.com/pictures/Pretty_Please.jpg
:D :D :D :D :D :D
Regard,
ScrewCaptain27
538
Proposed McLaren-style engine cover:
- Serj Tankian
ScrewCaptain27
538
Proposed Lotus-style fork nose, very similar indeed to the Lotus unit but with the longer section on the left.
Credit @KevTsImage
- Serj Tankian
ScrewCaptain27
538
Unassembled gearbox and rear suspension:
Temperature sensor location:
Credit @KevTs
- Serj Tankian
