Scuderia Ferrari SF90
keroro.90
keroro.90
Re: Scuderia Ferrari SF90
It seems that they are trying to measure the height (i guess those are height sensors) to try to figure out what's wrong with the FW and front suspension.
mmred
mmred
-3
so, do we know if the front wing stalls just at low speed?
it can be, mixed with the increase in aoa with rake
but it s a pretty normal fronw wing in the main aerea, i dont see it happening, its diferet just on the outside with benefit adverse to stall
LM10
LM10
120
mmred wrote:
16 May 2019, 19:16
If a possible stall of the front wing was the main issue Ferrari had, they would have not kept on saying that they don’t really understand what the problem is.
mmred
mmred
-3
LM10 wrote:
16 May 2019, 19:20
mmred wrote:
16 May 2019, 19:16
Yes it would have been a too big problem...
But the rake behaviour seems indeed an area of investigation
dans79
267
mmred wrote:
16 May 2019, 19:16
That's not a wise assumption. Changing the rake angle might fix the FW (if that's the issue), only to cause a different issue with the floor, or diffuser.
197 104 103 7
mmred
mmred
-3
dans79 wrote:
16 May 2019, 21:09
mmred wrote:
16 May 2019, 19:16
First
I was sarcastic
Second
I never assumed that solution
Third
The max rake changes also from track to track, there is an upper limit not a lower one problem
dans79
267
mmred wrote:
16 May 2019, 21:24
Third
Many of use on the forum are aware of this simple fact.
Every teams design philosophy has an upper limit. If All they had to do was increase rake, they would have done that already. Since they haven't and have openly admired they still aren't sure what the issue is, it's safe to assume that the fix will be a lot more complex.
197 104 103 7
mmred
mmred
-3
dans79 wrote:
16 May 2019, 22:08
mmred wrote:
16 May 2019, 21:24
Third
Nobody say the opposite
I was the first to say it was not an aero issue when everyone was focused on fwing weeks ago
I was even contradicted by many it
It is mostly a suspension problem with effects to aero
dans79
267
mmred wrote:
17 May 2019, 02:34
I disagree, I would say its probably 70-80% aero, and the rest suspension. If it was purely or predominantly suspension, they would have fixed it by now.
197 104 103 7
roon
roon
412
dans79 wrote:
17 May 2019, 03:15
mmred wrote:
17 May 2019, 02:34
Unless it involves coarse geometry. Moving attachment points and resizing large components will incur monocoque or gearbox changes. Otherwise I agree. This is still an aero formula. It's why Red Bull have remained competitive despite their power units. If something's wrong with a car, there's a good chance it's the aero.
mmred
mmred
-3
roon wrote:
17 May 2019, 04:07
dans79 wrote:
17 May 2019, 03:15
mmred wrote:
17 May 2019, 02:34
At low speed the behaviour is dominated by suspensions.... Red bull has indeed good aero and always had the best suspension
DRCorsa
DRCorsa
mmred wrote:
17 May 2019, 15:27
roon wrote:
17 May 2019, 04:07
dans79 wrote:
17 May 2019, 03:15
OK, that's the general opinion.
But in fact even at very low speeds, multi-element wings generate substantial levels of downforce.
Just for reference, the 3-element wing in the pic attached generates around 500N of downforce at 25m/s, i.e. 90kph.
3 element wing, 500mm chord length, 1.5m span. No endplates, no gurneys, no refining, just for reference.
dans79
267
mmred wrote:
17 May 2019, 15:27
roon wrote:
17 May 2019, 04:07
dans79 wrote:
17 May 2019, 03:15
So do you plan to continue ignoring Binotto's own comments?
https://racer.com/2019/05/15/binotto-sa ... eaknesses/
Right now we are losing a lot in each corner, not only in the last sector. Each single corner we are slow with quite a lot of understeer. That is not only downforce; we have seen something in the data which we need to analyze and understand so I think an early conclusion would be a wrong conclusion. We need a fix on this, but we need a proper analysis and try to understand the matter of balance, the matter of downforce and maybe even tire concepts.”
If they are having balance issues in all corners, that's not suspension, that's an aero issue with some potential suspension related entanglements.
197 104 103 7
mmred
mmred
-3
dans79 wrote:
17 May 2019, 16:38
mmred wrote:
17 May 2019, 15:27
roon wrote:
17 May 2019, 04:07
there arent fast corners in spain, thats where aero is tested at its max and they didnt test aero but ride height with those sensors, that speaks a lot, suspensions can cause indeed an aero problem if the ride height of the fw is too much compared to the competition, i still see no stall, primary cause suspension
dans79
267
mmred wrote:
17 May 2019, 17:23
Telemetry for turns 3, 9, and 16 say otherwise.
197 104 103 7
