Red Bull RB15
Post Reply
Re: Red Bull RB15
Morteza wrote:
11 Apr 2019, 12:24
Two different rear wing specs
https://pbs.twimg.com/media/D33TH9IUIAE4kmF.jpg
Via @AlbertFabrega
What's the difference? Thinner main plane?
Re: Red Bull RB15
godlameroso wrote:
11 Apr 2019, 23:12
Morteza wrote:
11 Apr 2019, 12:24
Via @AlbertFabrega
In his tweet he says Gasly's rear wing produces less downforce than that of Verstappen. I think he means Verstappen's wing is deeper. But is the difference really the thickness of the mainplane? The edges look different too, especially in the middle where the DRS actuator is located.
ray=out
Re: Red Bull RB15
Looking at the pictures, Gasly has a spoon style wing for lower downforce while Verstappen has a standard straight profile wing. The profile difference can be spotted by looking at the area of the DRS actuator support and pod (the actual pod and supports are different between the wings as well). Maybe they are going two different directions for setup this weekend, or at least for FP1/2.
roon
412
Re: Red Bull RB15
Morteza wrote:
11 Apr 2019, 12:24
Via @AlbertFabrega
scarbs pointed out they've added an additional support/pivot to the DRS mechanism, similar to TR and Ferrari. Visible in that image.
jerreclaus
Re: Red Bull RB15
Haven't found an answer to this here: I'm wondering for some time now why the "mid wing"-thing has these grooves on it. Is it pure aerodynamics like a trip wire or has it something to do with flexing or production..?
The McLaren has them too, and they do seem to influence the airflow a bit. Anyhow, the attention to detail is amazing..
Re: Red Bull RB15
It's to comply with the rules about what surfaces you can see from above/below - that's why they match the parts below.
jerreclaus
Re: Red Bull RB15
PhillipM wrote:
12 Apr 2019, 14:59
Ah yes. Wow, amazing. Thanks! =D>
SmallSoldier
473
Re: Red Bull RB15
Modifications to the end plate for the RB15
https://twitter.com/albertfabrega/statu ... 40064?s=21
etusch
131
Re: Red Bull RB15
Re: Red Bull RB15
Red Bull's modified front wing (lower photos)
Via @AlbertFabrega
markoc
Re: Red Bull RB15
Is it possible that mechanical issue from Bahrain was diffuser flexing?
Sieper
73
Re: Red Bull RB15
Those two struts were there already (implemented after winter tests, before Melbourne) but perhaps they were mounted incorrectly (not tight enough, too tight, one tight one not etc. Etc.).
I think they made a mistake in Either the spring stacks (but that can be solved) or possibly the weight (distribution) was incorrectly calculated/installed, wrong center of balance.
gandharva
252
Re: Red Bull RB15
markoc wrote:
13 Apr 2019, 09:37
The diffuser is an aerodynamic and not a mechanical part of the car.
Sieper wrote:
13 Apr 2019, 11:45
Those two struts were there already (implemented after winter tests, before Melbourne)...
Correct, but they are not pre mounted at factory. And the team told media that the culprit was factory pre mounted parts.
paddyf1
Re: Red Bull RB15
godlameroso wrote:
11 Apr 2019, 23:12
Morteza wrote:
11 Apr 2019, 12:24
Via @AlbertFabrega
Why has the picture on the right been reversed?
Sieper
73
Re: Red Bull RB15
To make the corner where the wing sits in similar (for more easy comparison) otherwise they would have been opposed.
Post Reply
