Scuderia Toro Rosso STR14
Re: Scuderia Toro Rosso STR14
HPD
395
I need to breathe!
jagunx51
86
Godius
217
Via reddit:
jagunx51
86
Godius wrote:
Fri Mar 15, 2019 12:59 pm
Via reddit:
https://i.imgur.com/vQXwGlt.png
what is a "white" layer on the rear brake cover for? looks like metal
ScrewCaptain27
578
jagunx51 wrote:
Fri Mar 15, 2019 1:36 pm
Via reddit:
It’s a ceramic coating. Reflects heat to the rim.
- Serj Tankian
Godius
217
Pics by AMuS
FW comparison, pre-season spec (above) v. in-season spec (below):
Stahlkocher
Stahlkocher
ScrewCaptain27 wrote:
Fri Mar 15, 2019 1:49 pm
Via reddit:
More likely keeping brake heat away from the wheel
JordanMugen
79
Morteza wrote:
Wed Feb 20, 2019 11:37 am
Toro Rosso have adopted RB's fluted rims
Still Apptech rims this year, or OZ Racing to match RBR?
roon
roon
449
Thu Mar 14, 2019 8:36 am
New rear wing:
https://uploads.tapatalk-cdn.com/201903 ... 5138aa.jpg
PH Albert Fábrega
Hadn't noticed it before, but their DRS actuator is similar to Ferrari's this year (integral swan's neck), and it was there in testing as well. Interesting parallel. Last year they both introduced shrouded mirrors at the same time as well, correct?
Godius
217
roon wrote:
Fri Mar 22, 2019 4:13 am
New rear wing:
PH Albert Fábrega
The DRS actuator design was already there on the STR13 RW. Ferrari used a different DRS actuator design last year. The vented mirror housing was introduced mid-season (british gp IIRC), Ferrari already had them available at the start of the last season.
roon
roon
449
Godius wrote:
Fri Mar 22, 2019 8:30 am
Indeed. Thank you.
CLKGTR
CLKGTR
88
JordanMugen wrote:
Fri Mar 22, 2019 2:26 am
It seems that Toro Rosso is still using AppTech wheels.
Racing Point switched from Motegi to BBS.
You can find all the infos like wheels and lubricants for all 2019 F1 cars here.
roon
roon
449
Godius wrote:
Sat Mar 16, 2019 4:14 pm
Interesting shape to the upper wishbone mounts.
Marti_EF3
325
