Mercedes W11 Speculation Thread
bauc
92
Re: Mercedes W11 Speculation Thread
OO7 wrote:
Fri Feb 07, 2020 8:41 pm
NathanOlder wrote:
Fri Feb 07, 2020 8:40 pm
Not seen that one before, where that from? Qualcomm obviously showing its not new.
It's from Photoshop. :D
Yes, Photoshop to represent how it might look
NathanOlder
163
Why is it that the best ones are always Photoshop :cry:
GoLandoGo
Lewis v2.0
King George has arrived.
63l8qrrfy6
63l8qrrfy6
373
Decided to post some updates here rather than the Merc PU thread:
-Car mechanical design for 2021 is well underway.
-Cooling system for 2020 will see a massive revamp, expected to be even smaller than last year's!! Not clear if it will be ready in time for Melbourne.
-Engine has seen the largest bump in power over a winter since the start of the hybrid era, unfortunately reliability has also been at an all time low for these engines. Early spec 2 is on the cards if the problems can't be solved in time.
-Several team leaders in Brixworth have recently left. Unclear what is going on.
HungarianRacer
HungarianRacer
27
Mudflap wrote:
Fri Feb 07, 2020 10:55 pm
... Does that mean they'll again have a launch-spec "A" chassis for the first (and potentially second) week of testing, then a "B" car with the upgraded cooling system and tighter bodywork for the Australian GP (or later)...?
63l8qrrfy6
63l8qrrfy6
373
HungarianRacer wrote:
Fri Feb 07, 2020 11:46 pm
I don't know and I would rather not speculate.
LM10 wrote:
Fri Feb 07, 2020 4:45 pm
wesley123 wrote:
Fri Feb 07, 2020 2:22 pm
LM10 wrote:
Fri Feb 07, 2020 12:21 pm
I’m sure the Mercedes will look completely different to last year’s car and it will be the only car on the grid with a big concept change.
They probably came to the conclusion that with last year’s concept there was no significant performance gain possible anymore. There is no other explanation for such radical changes with just one season remaining before we witness major regulation changes.
The 2019 car was already quite a big departure.
The development wall isn't all that sure either; they essentially dropped development halfway the season because they were that far ahead.
I don't get why people are assuming radical design changes. The sidepod is a very logical development that can carry over to the next season.
Then name me another change you would consider to be radical with regulations staying the same.
How can this year's sidepod development carry over to the next season? The cars in 2021 will be hugely different from now.
Afaik regulations regarding position of the crash structure doesn’t change. Which means such a solution can carry over.
Just_a_fan wrote:
Fri Feb 07, 2020 5:02 pm
I think the team have hinted at some new ideas in their public utterings, haven't they?
So? What they said was that last year design was all about downforce, and this year is more about efficiency, generally that just means taking drag out.
zibby43
zibby43
598
Thank you for those awesome tidbits of information on the PU side.
Overall, is the sentiment optimistic on the PU side?
Holm86
238
Hmm... after the 2019 season Mercedes admitted that their cooling system was not efficient enough to get the full potential out of the engine, so to run it even smaller seems weird
63l8qrrfy6
63l8qrrfy6
373
zibby43 wrote:
Sat Feb 08, 2020 12:37 am
I would say "reserved" is a more accurate description.
As I understand last year they were in a similar situation durability wise but were able to roll back some of the changes. The downside was that they made very little gains last winter but were able to fix the engines in time.
This year due to some sort of architecture change it isn't really as easy to revert to previous specifications.
63l8qrrfy6
63l8qrrfy6
373
Holm86 wrote:
Sat Feb 08, 2020 12:44 am
I think it will be a more efficient system. On top of that, the PU heat rejection is always reducing.
zibby43
zibby43
598
Mudflap wrote:
Sat Feb 08, 2020 12:49 am
As I understand last year they were in a similar situation durability wise but were able to roll back some of the changes. The downside was that they very little gains last winter but were able to fix the engines in time.
Thanks! Makes sense. Always look forward to your updates.
Sounds like they're doing their job and pushing the envelope to get better.
LM10
LM10
133
"Largest bump in power over a winter since the start of the hybrid era.." - How many times have we heard from other teams (including Mercedes) that Ferrari's power advantage was absurd and could not have been done legally? I wonder, if there will be any similar voices regarding Mercedes' sudden power jump next season.
63l8qrrfy6
63l8qrrfy6
373
LM10 wrote:
Sat Feb 08, 2020 1:29 am
I'm sure FIA can find room for a third FFM if it comes to it :))
Maybe one for oil too!
zibby43
zibby43
598
I'll be interested to see if the team leader departures were poaching from other teams or internal dismissals due to failing to meet targets, etc.
Lots to tease out from that information.
The bit about the cooling architecture revamp ties in nicely with the article I linked previously. Forgot to include some of the excellent drawings by Giorgio Piola.
"But it is the unique Mercedes T-section chassis shape that featured on last year’s car which could (if, as expected, it's retained) allow the new sidepod arrangement to be even more powerful. Aft of the cockpit area, the Mercedes chassis is highly unconventional in shape."
"In this respect, it resembles the 1987 Benetton chassis (see drawing below), which would form a T-shape if a section were vertically cut through it.
Such a shape has allowed Mercedes to bring the radiator further forward than would otherwise be the case, helping centre the car’s masses towards the middle, which will give a more agile and responsive car, especially in slow-speed corners."
Source: https://www.formula1.com/en/latest/arti ... vtEnF.html
