Red Bull RB16
Post Reply
Godius
186
Re: Red Bull RB16
jagunx51
185
Re: Red Bull RB16
Marti_EF3
56
Re: Red Bull RB16
Capharol
21
Contact:
Re: Red Bull RB16
jagunx51 wrote:
29 Feb 2020, 02:01
https://i.imgur.com/bFw1MUk.jpg
what are you trying to show us?
Re: Red Bull RB16
Just_a_fan wrote:
28 Feb 2020, 12:20
The teams are trying to pull "clean" air down towards the front of the floor etc. and these devices are a good way of doing it. It's a fairly obvious device once you've got the big vortices in place from the vertical boards.
godlameroso wrote:
06 Nov 2019, 06:24
Red Bull should really thank Honda, not only are they getting a good power unit, they also had the winning design for the side pod end fences all along.
https://www.pixelstalk.net/wp-content/u ... esigns.jpg
https://imgr1.auto-motor-und-sport.de/M ... 639893.jpg
Mercedes isn't even close.
https://imgr1.auto-motor-und-sport.de/R ... 642398.jpg
Granted this doesn't take the rest of the car into consideration but this area is very important. I feel that Toro Rosso was used as a Guinea pig as it sprouted a very rudimentary version sometime around Singapore.
https://imgr1.auto-motor-und-sport.de/T ... 642417.jpg
Of course the first team to introduce this concept this year was Haas.
https://imgr1.auto-motor-und-sport.de/H ... 623246.jpg
But they haven't gotten it to work any better than when the season started despite constantly modifying this area.
Re: Red Bull RB16
Haas VF-18 was the first to use those.
ME4ME
79
Re: Red Bull RB16
Not sure what to make of the Red Bull this year. They seem to have bolted on a massive upgrade package, which is impressive. Detail and refinement is probably the best Red Bull has ever produced. The car seems rapid in high and medium speed corners. Strong enough on the straights thanks to Hondas progress, and good on braking as usual. Just as last years RB15 it's still questionable how stable the RB16 is in mixed conditions. So far it seems prone to sidewinds, and you've got to wonder if that's ever solvable with the high rake philosophy. Probably just a (acceptable?) draw-back they've got to life with.
Not yet convinced this will be enough but we'll see.
So far I think it's more likely we'll see a RB driver spin in a race than a Merc retire with PU issues. Both will probably occur at some point. Comparing to last season though, Verstappen surely has a much better car to start the season with, so thats one very positive way to look at it.
jagunx51
185
Re: Red Bull RB16
Capharol wrote:
29 Feb 2020, 11:57
jagunx51 wrote:
29 Feb 2020, 02:01
it looks like RB16 has only 1 vertical element on the nose, while RB15 has many of it .... I thought it isnt allowed....we also see the green color behind the hole (or inside?), what is it?
comparisson from RB15's nose
Alfa Romeo
GioKer32
Re: Red Bull RB16
jagunx51 wrote:
01 Mar 2020, 08:41
Capharol wrote:
29 Feb 2020, 11:57
jagunx51 wrote:
29 Feb 2020, 02:01
https://s.yimg.com/ny/api/res/1.2/hbdct ... 109b331c0a
https://cdn-8.latimages.com/images/mgl/ ... 2_9061.jpg
https://www.racefans.net/wp-content/upl ... 1722-1.jpg
Alfa Romeo
https://f1tcdn.net/gallery/var/resizes/ ... 26/085.jpg
https://preview.redd.it/emphllb54vg41.j ... b724f1aa15
According to the regulations, from a front view you mustn't be able to see anything behind the nose itself, that's why they used some vertical elements inside the hole.
Probably they discovered that less elements work better (aerodinamically) and they switched to the actual solution.
I don't think it's illegal (they wouldn't have brought this solution if it had been illegal) and the green colour, in my opinion, is just flow vis to visualize vortices exiting the nose.
Of course Alfa Romeo use the same solution to create that hole in the nose bulge.
cbar195
Re: Red Bull RB16
GioKer32 wrote:
01 Mar 2020, 13:23
jagunx51 wrote:
01 Mar 2020, 08:41
Capharol wrote:
29 Feb 2020, 11:57
Alfa Romeo
The vanes are inside the nose to get around the rule following rule:
Only a single section, which must be open, may be contained within any longitudinal vertical
cross section taken parallel to the car centre plane forward of a point 150mm ahead of the
front wheel centre line, less than 250mm from the car centre plane and more than 125mm
above the reference plane.
Normally if the nose has a hole in the front, then it will form 2 longitudinal cross sections. By having the vanes (notice they are all angled or curved), then there is only the one cross section that the rules specify. I suspect Red Bull has just moved the vanes deeper in the nose compared to last year.
ispano6
143
Re: Red Bull RB16
Apologies if this is a re-post. This channel has some great video/audio of all of the cars.
e36jon
66
Re: Red Bull RB16
Image (Thanks to Amus for the amazing top photo.)
Has anyone discussed the changes to the suspension rockers? RB16 top and RB15 bottom. The new rockers seem HUGE compared to previous designs. Any thoughts on what drove the changes? Are they just exposed more due to bulkhead geometry now?
These new rockers also seem to be designed using an optimization program as the new geometry is not something someone would come up with. The front uprights on all of the cars seemed to go through a similar evolution 7 or 8 years ago, where they went from pretty rational forms (Conical, cylindrical, etc.) to the very organic forms we have now. Seemed to happen overnight and across all of the teams. I wonder what changed?
And, just for a laugh, the red damper appears to have a remote reservoir, that has a remote reservoir, that has a remote reservoir... Cracked me up for some reason. Sorry.
scheffers
Re: Red Bull RB16
e36jon wrote:
10 Mar 2020, 20:52
https://imgr1.auto-motor-und-sport.de/R ... 672330.jpg (Thanks to Amus for the amazing top photo.)
https://pbs.twimg.com/media/D_xBOEzXkAALy3r.jpg
Nice picture indeed. Going more and more towards topological design yes. Evolution of CAD/CAE software and machining possibility's , good stuff. The possibility's have been there for a while, but the interplay with real world physics and experience is a very important factor in designing parts. Cool to see the clear evolution here.
Re: Red Bull RB16
e36jon wrote:
10 Mar 2020, 20:52
Bypass canisters for position sensitive damping, the heave element is also acceleration sensitive not just velocity.
Re: Red Bull RB16
e36jon wrote:
10 Mar 2020, 20:52
I reckon the rockers are flipped backwards for 2020 to make space for the steering bits?
Post Reply
