McLaren MCL35M
elldizzle
elldizzle
Re: McLaren MCL35M
Lot of flow viz on lando's floor on sky at the moment..
f1rules
f1rules
569
Re: McLaren MCL35M
@SomersF1
one more from @racingtech5
BosF1
BosF1
Re: McLaren MCL35M
also clearly visible that there is no 4th flow conditioner on the floor, contrary to suggestions earlier in this thread.
Re: McLaren MCL35M
BosF1 wrote:
07 May 2021, 12:45
Look properly and you will see the 4th element as posted earlier in this tread... Clearly they removed it now...
CjC
CjC
Re: McLaren MCL35M
Stu wrote:
07 May 2021, 11:48
f1rules wrote:
02 May 2021, 14:45
https://pbs.twimg.com/media/E0Xsyg0WEAM ... name=large
From @Graftechweb
The real stand-out for me from that picture is the shear quantity of floor visible on the McLaren as compared to the other two. Very narrow side pods.
And James Key said they were compromised in this area due to the tokens. It’s definitely a case of what might for Mclaren
Just a fan's point of view
trinidefender
trinidefender
317
Re: McLaren MCL35M
Were the new parts running on both cars?
f1rules
f1rules
569
Re: McLaren MCL35M
floor only with lando but they should have for both so probably for both in fp2 if results where satisfying
yeah new floor for daniel now
McFAN
McFAN
19
Re: McLaren MCL35M
f1rules
f1rules
569
Re: McLaren MCL35M
nice high res of the bargeboard area
https://pbs.twimg.com/media/E0yXj2iXEAA ... name=large
BosF1
BosF1
Re: McLaren MCL35M
mclaren111 wrote:
07 May 2021, 13:03
BosF1 wrote:
07 May 2021, 12:45
The picture you assume is the evidence doesn't actually show four elements. There is a shadow from the three known elements and a metallic bit on the inside of the floor, but that ain't a fourth element.
Besides, it would not make sense at all to add or remove carbonfibre bits onto the floor during a weekend. The process involved in fabricating these complex parts doesn't include glueing pieces on it or removing them as they like. It's way more complex. There are two iterations of the floor this weekend and neither of them contain four aerodynamic elements in front of the rear tires.
Re: McLaren MCL35M
Actually on the mclaren that entire outer strip is bonded in and replaceable.
Re: McLaren MCL35M
Side View of New Floor...
Macklaren
Macklaren
Re: McLaren MCL35M
New floor and front wing. Finally the big update is here!! VERY EXCITED
**sees P11 and P14 in FP2** #-o
srsly though, surprised they changed the floor and the FW at the same time. Surely they would want to evaluate each impact separately over a weekend?
aerofoilf1
aerofoilf1
247
Re: McLaren MCL35M
f1rules
f1rules
569
Re: McLaren MCL35M
I just hope it works or its the sec new fw that is dropped
