axle wrote:RacingManiac wrote:have not seen a car with brake caliper clocked like that in F1 in forever...
Front or rear? The front ones look normal to me, can you explain what you mean? Cheers
Both brakes look to be on the outer most side of the car. I don't understand why they would do this other than perhaps there is some compromise being made for aero.
Most of the time the brakes are mounted the opposite in order to get the mass of the calipers as close to the cg of the car. Newey likes mounting the calipers at the bottom in the aim to improve the cg (lowering it).
