2018 Bahrain Grand Prix - Sakhir, April 6-8
Locked
dans79
267
Re: 2018 Bahrain Grand Prix - Sakhir, April 6-8
muramasa wrote:
29 Mar 2018, 18:41
Cars are difficult to follow for sure, but even if fix the aero, tyre gets useless after few attempts of attack so races like Shumi vs Alonso at Imola 2005/06, Petrov vs Alonso at 2010 Abu Dhabi will not happen.
Fix both aero and tyre. Tyre is actually bigger problem than aero, put Bridgestone/Michelin to current car and racing will be totally different, or back to what is was before Pirelli era ie normal racing.
The aero is the cause of the "tire" problem.
197 104 103 7
F1NAC
163
muramasa wrote:
29 Mar 2018, 18:41
IT would be the same. Pirelli makes durable tyre as f1 wants.
You would then have 1 stop races with cars stacked behind others because they couldn't get close enough.
Let's go back to 80's and with ground effects 8)
Since it's a night race if anyone can capture a shot of the tailpipe flames during downshift, I'd really appreciate it. Flame color will tell us more or less what they're burning and at what temperature.
muramasa wrote:
29 Mar 2018, 18:41
Have you ever heard of "fan boost?"
It is a system I proposed to allow cars to follow closely. The cars would have small downforce generating fans that would be enabled when cars come within a half second of each other. Dirty air? No problem.
ferkan
31
How is it possible that in formula where there is hard cap on fuel limit, similar performing engines are able able to have such a big difference in fuel consumption?
I dont buy that Ferrari has fuel consumption issues. That was a AMUS way to explain Ferraris lack of pace in testing IMO.
iotar__
PlatinumZealot wrote:
31 Mar 2018, 00:58
Isn't it DRS type of effect, artificial, impure but dangerous/random (turning on/off)? At least DRS is limited to straight (simple) and consistent with braking. How would it be connected with set up, tyres or measured (DF), changeable (related to weight/tyres/tempetures) or constant? You might as well force the car in front to slow down in 0,x s using negative DF device :? . Nevermind.
I also have an idea :wink: : why didn't the thought of painting Halo in helmet colours cross minds of F1's big-bucks-thinkers? It would solve problem of visibility of helmets and compliment them in identifying drivers.
I see overtaking, dirty air and 3 engines are still on the agenda:
- Is the great discovery of dirty air effect and invention of "evil 3 engine rule preventing overtaking" by chance an effect of Hamilton behind Vettel or Verstappen behind Haas? Both issues will disappear when it is their turn to lead.
- F1 audience can even use inablity to overtake with DRS as an argument against it.
Weekend prediction: more whinging about engines
iotar__ wrote:
31 Mar 2018, 02:08
31 Mar 2018, 00:58
Easy. Use standard fans and limit the maximum rpm of the fans.
It's not any more dangerous than failed DRS, failed brake by wire, delaminated tyres or any other failed part outside of the safety cell. It's just a fan connected to the Energy store.
Wass85
Why not allow DRS anywhere on the circuit as long as you're less than 1 second behind.
sosic2121
the EDGE wrote:
29 Mar 2018, 18:00
The problem that needs addressing is twofold, cars to difficult to follow to race and too many circuits with only 1 racing line
Then we can be rid of DRS forever
I also think this is a good idea. Maybe use higher camber on the outside of the corner.
And of course something has to be done with aero.
In theory, keeping this fuel flow limit but decreasing amount of fuel would allow faster car to save fuel and then use higher power mode to overtake, but this would probably backfire....
jonnybgoode
Isn't the reason those Bridgestone michelin days seemed better the fact that refuelling during the races was allowed? Then you can have tires that last forever and drivers can push. It opens up different strategies...
Juzh
161
ferkan wrote:
31 Mar 2018, 02:01
ERS efficiency.
Marci
Juzh wrote:
31 Mar 2018, 21:10
ferkan wrote:
31 Mar 2018, 02:01
ERS efficiency.
But some articles stated that sometimes Ferrari PU needs around 10kgs more fuel on a race distance,that is a lot.So there is a big difference between the thermal efficieny of the Mercedes PU and the Ferrari PU? I also find it really strange that at this level of competition there is more than a few percent difference between their efficiency.
lawnmower
-1
engine modes comparison :D
Mr.G
34
lawnmower wrote:
31 Mar 2018, 22:30
https://uploads.disquscdn.com/images/c6 ... b5b5a8.png
Ferrari is the same size as Mercedes just captured from distance :D
Mr.G
34
Mr.G wrote:
31 Mar 2018, 23:10
lawnmower wrote:
31 Mar 2018, 22:30
Ferrari is the same size (or bigger considering number of bolts) as Mercedes just captured from distance :D
Locked
