Zynerji wrote: ↑19 Dec 2020, 17:11
Jolle wrote: ↑19 Dec 2020, 17:04
Just_a_fan wrote: ↑19 Dec 2020, 16:55
Some say that way, some that high rake loses. Not long now and we'll know either way.
With a high rake you need more width to create a low pressure area and more trickery to seal the floor, because the gap is bigger. Mercedes will still have more floor area before the diffuser. And with the flow under the wishbones instead of over it with the wider nose, they have more air to play with.
With the tapered floor in front of the rear tyre, any possibility of edge extraction to effectively increase the diffuser volume?
The diffuser’s job is to create a low pressure area under the car, its not the diffuser that creates the downforce, it’s the floor. So air coming in from the sides of the floor into the diffuser is bad. Not only does this higher the pressure under the car, it also stops this air to accelerate to create this low pressure because it’s blocking the diffuser.
Somehow they need to find a cheap (in development tokens) solution somewhere on the barge boards or the inside of the front wing to create a very precise vortex to block air leaking in. Of course, redbull has a good shot of finding this magic bullet but they don’t have much to play with, at least, less then Mercedes who to begin with, have a smaller problem.
