Igora Drive replaces Sochi in 2023
astracrazy
astracrazy
56
Re: Igora Drive replaces Sochi in 2023
notsofast wrote:
Sat Jun 26, 2021 11:00 am
Connect the pit exit to turn 4, That would allow for interesting pit strategies.
It wouldn't improve anything, all they would do is what they did with Silverstone and lower the pitlane speed.
outer_bongolia
So right!
That would reduce the time lost in the pitlane by quite a few seconds...
Skeptical scrutiny is the means, in both science and religion, by which deep thoughts can be winnowed from deep nonsense.
Carl Sagan
Unf
-8
notsofast wrote:
Sat Jun 26, 2021 10:42 am
Interesting pit lane configuration
Bit similar to Zolder.
_cerber1
232
At the Igora Drive Autodrom, the first layer of asphalt was laid on the new configuration of the ring road. Modernization work started in the summer of 2021.
The new configuration will be almost 1.1 km longer and its total length will be 5,182 m. Like the existing version of the track, it was designed by Hermann Tilke. The new configuration will organically use the interesting terrain, which will make the track even more technical and exciting. The existing version of the track will also be available for amateurs and professionals in the world of auto and motor sports.
Modernization work is carried out in close cooperation with the International Automobile Federation (FIA) and Formula 1, as well as the International Motorcycle Federation (FIM) and MotoGP. The modernization will use the most modern solutions to ensure the safety of riders, including the increase in departure zones and the installation of additional Tecpro barriers. The work is carried out in accordance with all the requirements of the FIA ​​and FIM. This will renew the licenses for the existing configuration and obtain Grade 1 and Grade A licenses for the new one.
The modernization will also affect the Igora Drive infrastructure. The changes will create an even more functional space for teams and pilots to have exciting races on the Igora Drive circuit. Expanded spectator zones will enable guests to enjoy every second of the spectacular competition.
The exit feeds in just before a corner meaning we're likely to see Monza-style incidents as exiting cars will be fully up to speed and on the inside of the corner - effectively fed in to an early apex. Will require any cars on the track itself to go around the outside of an exiting car in to T2. Either there will be clashes on the apex or the on-track car will be at risk of running wide on exit.
Getting the pit exit right will be important - the run from the pit exit "hairpin" to T2 is slightly longer than the track is from T1 to T2. So, getting a good run around the pitlane exit "hairpin" and then down the exit lane, might mean an exiting car is faster in to T2 than an on-track car, but in a less favourable line for T2.
If there isn't an issue here at some point during the weekend, I'll be surprised.
Turbo says "Dumpster sounds so much more classy. It's the diamond of the cesspools." oh, and "The Dutch fans are drunk. Maybe"
Mogster wrote:
Wed Jun 30, 2021 8:17 am
Proposed extension to the end of the lap, whiff of Baku S2? Main straight extended but entry will be very slow.
https://pbs.twimg.com/media/E5CQO9uVEA ... =4096x4096
Doesn't look to make it any easier to get an overtake done. Losing the hairpin and replacing it with a long sweeping switchback isn't necessarily a good thing. Effectively, T1 will be the only chance for an overtake as the rest of the track is fast and flowing - exactly wrong for these cars to follow closely.
NathanOlder
164
Just_a_fan wrote:
Wed Sep 22, 2021 9:16 am
Although luckily 'these cars' wont be racing there. So hopefully it's all good and the racing will be great [-o<
GoLandoGo
Lewis v2.0
King George has arrived.
SiLo
126
The straight before T13 is quite long, and those corners will likely be flat coming onto it so I think that will also be a place to overtake as well.
Felipe Baby!
NathanOlder wrote:
Wed Sep 22, 2021 10:07 am
Some people are just so optimistic. Bless. :lol:
SiLo wrote:
Wed Sep 22, 2021 10:14 am
I guess it'll depend on how close the follow car can get through the curves. The cars understeer at speed anyway - because it's the safe way to set up the cars - but if they start to understeer too much, the front tyres will go off very quickly.
I guess we'll see once we get there.
NathanOlder
164
Just_a_fan wrote:
Wed Sep 22, 2021 10:43 am
Don't you think the racing will improve with the new cars ? Surely the amount of research and the figures from wind tunnel and CFD simulations show it will be much improved compared to what we currently have ?
GoLandoGo
Lewis v2.0
NathanOlder wrote:
Wed Sep 22, 2021 1:40 pm
I'm becoming increasing cynical with each candle added to my birthday cakes. :lol:
Do I hope the racing will be better? Yes, of course. Do I expect it to? Well, now that's the issue...
