stibbles wrote:Tomba wrote:Ray wrote:...
Piquet. Go. Home.
And McLaren are miles ahead because of the close relationship of the designers of the common ECU. It's so blantantly obvious, yet the press is trying to shoo everyone away from that fact.
Two points I totally disagree with.
First of all, it was Piquet's first race, and Kovalainen last year already proved it's not an easy track to start your career in. Furthermore, Piquet's Renault was hit during the start and was hard to drive as of that moment. He therefore was unable to keep a decent pace. Give the guy a break, he'll improve and has the team behind him.
As for McLaren being miles ahead, Ferrari are pretty well on the pace too but are apparently still figuring out how to keep their engines reliable with the ECU.
I don't expect any McLaren advantage to last for more than a 4 races (at least I hope so).
I'm a bit p...ed at the mind numbing ECU barbs going on here, I just joined thinking this would be a bit better informed than some of the flame baiting trolling sites. And I start to read all this ECU engine failure stuff. None of the teams are blaming their failures on the ECU. Maybe a heat issue more likely. Just didn't design the aero for sufficient cooling. Remember that there was only 11% humidity, which makes cooling more challenging.
Remember these ECU's are closed loop systems - inputs are just temp (probably a variety of sources), variable valve timing (if used), advance, fuel (based on airflow and temp) and driver selected paramaters. This may be a simplified, but the same parameters should apply to any ECU:- just a simple matter of translation to the new system. If a team like Ferrari can't translate their own maps to a new system selected by the FIA then .....
Just saw an F1-live article eplaining partly their engine going up in smoke in the Melborne GP,
http://en.f1-live.com/f1/en/headlines/n ... 1855.shtml.
Am quoting them entirely below:
Engine design had nothing to do with the failure of both Ferrari power plants in the recent Australian Grand Prix according to Michael Schumacher.
Ferrari did not encounter engine problems in 10,000 km of pre-season testing, which counters speculation that the McLaren ECU can be blamed.
In an interview with Auto Motor und Sport, Schumacher did not reveal the actual cause of the Albert Park failures, but he insists that they had "nothing to do with the engines themselves."
"I don't want to go into any more detail," he added.
Rumours on Thursday at the scene of the Malaysian Grand Prix indicate that the problems were of an aerodynamic nature, triggered by the intense heat of the Melbourne circuit.
Coulbe be this is just PR-speak for an "overheating engine" - due to lack of "aerodynamics" (ventillation).
