Innovo 2012 F1 Car - Tozza Mazza and JordanGP
jordangp
Contact:
Re: Innovo 2012 F1 Car - Tozza Mazza and JordanGP
astracrazy wrote:i know what you mean. Thanks
What height/depth (how thick) do you do the floor? 10mm?
Mine is predominantly 5mm. If you look at the floor thickness, at the very outside edges, you can see it it much thinner than 1cm.
jordangp
Contact:
Twitter
via @InnovoF1
Here's a look at our Turkish GP spec car
Revised:
Rear Wing & Endplates
Beam wing
Floor
Exhausts & Sidepods
EDIT:
Practice Results: Heidfeld P3 Kubica P5
Qualifying Results: Heidfeld P2 Kubica P3
CottrellGP
I like your rear end, big man
Dan Cottrell
Master Of Innovation!
jordangp
Contact:
Everyone loves my rear end :wink:
Doesn't seem to get the results though. Worst results of the year this weekend.
CottrellGP
This is F1 Technical not some porn site Innovo!
Dan Cottrell
Monster_Energy_F1
Contact:
Well, you can't really help the retirement, and 4th place isn't too bad. Wait for the race report to see why this happened! :lol:
Markus
I would like to start building my own F1 car in Google sketchup. I just wanted to ask if you started out with some sort of a starter pack or did you guys build everything from scratch?
BTW amazing work on your car.
N12ck
Markus wrote:I would like to start building my own F1 car in Google sketchup. I just wanted to ask if you started out with some sort of a starter pack or did you guys build everything from scratch?
I personally started from scratch, as I built the car before I seen the starter pack,
Budding F1 Engineer
Markus
Do you know where you can get that starter pack?
N12ck
well I didn't use it so I don't really know where to get it from,,, ask Jordan GP
Budding F1 Engineer
jordangp
Contact:
You will be unable to obtain a starter pack unless you are a member of Formula Sketch, or a pending member for 2013.
etsmc
jordangp wrote:You will be unable to obtain a starter pack unless you are a member of Formula Sketch, or a pending member for 2013.
And even thats hard enough :evil:
jordangp
Contact:
How so? Just ask for it
Markus
Well the site is down so it´s quite hard to find contact details.
jordangp
Contact:
Markus wrote: Well the site is down so it´s quite hard to find contact details.
Yes, but for members of Formula Sketch, it isn't an issue, which was what I was stating.
Hopefully they'll get the site up and running again soon though.
