Parametric Racecar Aerokit design [MVRC]
CAEdevice
39
Re: Parametric Racecar Aerokit design [MVRC]
Yes, I think you are right. There are two possibilities: to lower the diffuser (especially at the sides) reducing drag or to find a way to feed it with more air (the high nose helps the central channel, but not very much for the side channels).
Zynerji
Zynerji
If this had a TensorFlow plugin, the possibilities would be utterly astounding.
machin
184
CAEdevice wrote:
Wed Dec 20, 2017 7:25 pm
Was Variante working on trying to feed the diffuser side channels from the side of the car?
rjsa
rjsa
69
Yes, he has a rounded floor edge amid ship. Did nothing for me but choke the front diffuser.
I have a pair of "horns" protuding from the rear diffuser edge that brought some flow into the side channels. And a whole lot of very twisted streaks within the diffuser volume.
Let's see if I can post a picture later.
variante
100
machin wrote:
Wed Dec 20, 2017 8:31 pm
Yes, and I find it surprising that not many people are using this approach. Sure, it takes a while to get it to work, but it looks like a better way (at least, it looks so to me).
The biggest downside is what rjsa mentioned: you must deal with the front end airflows, somehow.
The "recipe" that I found is this:
- front wing airflow is evacuated in a dedicated channel which ends just above the diffuser, where there is quite a low pressure
- the leading edge of the floor is a splitter that takes front wing airflow away from the diffuser
- therefore the diffuser is forced to take air from elsewhere: slantwise, from the sides of the car
- that airflow happens to be of good quality, and its oblique motion helps creating strong vortices inside the diffuser itself
I'll post some images too, and a more detailed analysis
machin
184
More pictures of both your cars would be cool. 😎
Matteo is far too modest and self-deprecating though; he may have a conventional car layout without any fancy front wing evacuation ducts, but let's not forget he also designed the most aerodynamically efficient car... it makes me wonder; what could you guys all achieve if you worked together to design one ultimate car?!?! 🤔
schwepes
machin wrote:what could you guys all achieve if you worked together to design one ultimate car?!?! Image
I'm not sure if too many "technical directors" in one team would lead to any constructive result :-k .
Sometimes I cannot even make compromise with myself regarding some solutions :lol:
machin
184
Yes, I do agree! And I think that personal glory (as opposed to shared glory) is a big motivating factor!
rjsa
rjsa
69
variante wrote:
Wed Dec 20, 2017 11:40 pm
I also have the air extracted from the diffuser to the back. My duct is a tad shorter though, just long enough to cover the rear suspension.
Here the bottom:
The genie is out of the bottle now machin, the front diffuser you were curious about. This isn't the highest downforce version however...
machin
184
Wow, that is some seriously nice underbody design.... 😳 👍
rjsa
rjsa
69
:oops: tks!
variante
100
I was't sure about showing so much of the car, but rjsa did and hopefully all the other MVRC guys will follow this path.
When I was a beginner, I really struggled to find any valuable information about aerodynamics, and today the web and most of the books are still full of misconception or partial explanation about the functioning of aerodynamic devices (...not to talk about university courses, because those are too generic and totally fail to form a competent class of aerodynamicists...at least in Italy).
So let's make this altruistic move and show something. A detailed article will follow on the Variante thread.
I'll quote myself for a brief description of what's going on under this car:
I envy rjsa's front end, and especially the central part of the front wing, which has been giving me headaches during the whole season.
rjsa
rjsa
69
That's a lot of work done by that rear diffuser. I have a lot to do there.
machin
184
Nice one Variante, so cool, you can really see nice flow from the sides of the car on the velocity plot.
My personal opinion is that the championship should release more CFD pictures of the cars... I know that you guys want to win and don't want to give away secrets... but I don't think that isometric underfloor surface pressure plot gives too much away (especially if done at low resolution). But it would show the relative aero performance of the cars...
I think it would also help to grow a bigger "spectator" base for the championship.
CAEdevice
39
I am not sure about publishing the CFD data/images: I think that realism should be the guideline, and in real races is not possibile to see pressure and velocity plots. On te contrary, it is possibile to see the more geometric details of the car.
I would agree about showing more CAD data and better renderings. Sometimes it is impossible to understand details that would be clear if watching a real race.
It would help to see pictures of gray streamlines running around the car or coming out from the diffuser, as it happens in the track when it rains or the car crosses a stretch of gravel or dust.
Anyway, the 2017 season is over and "the emperor has no clothes" so here are some images of the underfloor of the MP005B.
