That´s exactly their intention, but it´s easy to say and togh to accomplishdiffuser wrote: ↑Mon Jun 11, 2018 1:10 amGround Effect wrote: ↑Sun Jun 10, 2018 11:29 pmNewey turned down Ferrari at least twice, for a lot of money! Brawn said he didn't fancy returning to a team, I think Mclaren looked at him before Zak. If my memory serves me, Ron wanted Ross as well, before Capito was hired.Darth-Piekus wrote: ↑Sun Jun 10, 2018 10:46 pmMclaren has to promise a good amount of money and total freedom to Newey or Brawn and of course show them a plan that will persuade them to come back. I don't see why they can't bring them back.
I think Newey has found his home in Red Bull, can't see him leaving, except maybe if the team is sold and he doesn't like the new structure. He's even working on hyper cars for Aston Martin.
You need to do what Ferrari did and find the Next Newey. OK, whether he's the next Newey is still a long way off but when the new regs came out Ferrari was way ahead of RBR. Basically it someone that was promoted from within.
The car is not that draggy, I think you need to read the forum again. It's the suspension that's the problem, nothing to do with drag. Because of weak performance in slow speed corners, they have to run higher downforce levels than others, that is what adds drag and is why they have a slightly lower straight-line speed than Renault or RB.Vasconia wrote: ↑Mon Jun 11, 2018 8:23 amBut updates are not bringing the expected performance. Plus this car is draggy as hell, in the past they blamed the Honda PU but as we can see the problem is the car (well, the team). I am pretty sure that even with a Mercedes PU they would be the slowest team with this PU, by far.
They ran high DF (big wing) because they had no grip in low speed corners. Besides that, not much fundamental dragnirvaand wrote: ↑Mon Jun 11, 2018 8:27 amThe car is not that draggy, I think you need to read the forum again. It's the suspension that's the problem, nothing to do with drag. Because of weak performance in slow speed corners, they have to run higher downforce levels than others, that is what adds drag and is why they have a slightly lower straight-line speed than Renault or RB.Vasconia wrote: ↑Mon Jun 11, 2018 8:23 amBut updates are not bringing the expected performance. Plus this car is draggy as hell, in the past they blamed the Honda PU but as we can see the problem is the car (well, the team). I am pretty sure that even with a Mercedes PU they would be the slowest team with this PU, by far.
Lost boost pressure due to a broken charge air cooler pipe
The more-inbound pull-rod position means the upper wishbone needs to have massively-greater bending stiffness. That adds unsprung weight. It is also yet another (relatively) undamped spring (bending).godlameroso wrote: ↑Mon Jun 11, 2018 2:51 amMotion ratio, the closer to the upright the pull rod is connected, the lower the installation stiffness needed. This is because there is lower lever action. The closer inboard you locate the pull rods the higher the installation stiffness needed because the control arm introduces a lever action. The closer the pullrod is connected to the chassis relative to the upright the lower the effective spring rate. But this isn't necessarily bad, I still think the problem is aero and not suspension. Better aero will fix 80% of their issues once they get the setup sorted.diffuser wrote: ↑Mon Jun 11, 2018 12:18 amthis is something that was discussed back in may but if you look at the connection of the pullrods to the rear suspension. They're alot closer to the middle that any other team I've looked at .. never understood why. I always thought that the wider apart they go the more pull you get.
https://pbs.twimg.com/media/Deb5kgoWAAAISrY.jpg:large
https://uploads.tapatalk-cdn.com/201803 ... 769d08.jpg
https://pbs.twimg.com/media/DXMo1DwXUAAJyBU.jpg
https://i.redditmedia.com/68lMicoibCuco ... 847d1210cd
There was a time when mcLaren had to run a harder suspension cause the aero lost alot of df with just small amounts of movements. Not sure that is still true today.techman wrote: ↑Mon Jun 11, 2018 4:42 ami wonder if the mclaren runs a stiff suspension. normally softer suspesion does help to get more mechanical grip but the downside is you dont get the aero to work properly. overall the mclaren was never a good car. it was always good in fast corners thats why eric usually boast about gps trace last year blaming honda for everthing but the reality they ran max drag to achieve fast cornering, but they were always lack ing mechanical grip which hondas Arai complained to mclaren in 2015 but they never did anything to fix it instead blamed Arai .funny , what goes around comes around
I don't know if it's my biased view, but I think McLaren issues with suspension, pipes and etc is more recurrent than in other BIG teams.
The rear suspension that McLaren is using is heavier and stiffer than other solutions.techman wrote: ↑Mon Jun 11, 2018 12:45 pmwell from my understanding there are few ways you can get mechanical grip.
1. have a lighter car. which i believe mclaren is good at. probably one of lightest car out there. is the honda more lighter than renault?
2. running softer suspension. but the negative for this is , it does not help aero
3.. adding rear downforce. and this is what mclaren doing now at the moment. but this will cause a litte more drag.
my guess is mclaren is running more drag for sometime now because they are running a very stiff suspension. mclaren need to try different suspension setups and compare. Another problem with mclaren is that mclaren is not aero efficient compared to redbull. redbull can generate the same downforce with less wing compared to mclaren. mclaren found a scared scapegoat partner like honda to put the blame but now i think the reality now will help them to fix these issues for future. the funny thing is when i did mention this in this forum that mclaren are running more drag. i was called a troll.![]()
You were a troll, the way you conducted yourself, and apportioned all the blame on mclaren when actually the blame was more like 65% on Honda.techman wrote: ↑Mon Jun 11, 2018 12:45 pmwell from my understanding there are few ways you can get mechanical grip.
Please stop with the BS, if you don't know ask.techman wrote: ↑Mon Jun 11, 2018 12:45 pmwell from my understanding there are few ways you can get mechanical grip.
