2018 McLaren F1 Team - Renault
Post Reply
Nonserviam85
Re: 2018 McLaren F1 Team - Renault
techman wrote:
11 Aug 2018, 08:47
Just interested to know , do you guys think mclaren can beat redbull next year? now that redbull has a gp2 engine
Many people here thought they can beat them this year as well so...
makecry
19
techman wrote:
11 Aug 2018, 08:47
Yup coz Honda 2015-2017 will be same as Honda 2019. At least be a bit creative with your trolling.
Raleigh
29
McLaren isn’t convincingly beating Toro Rosso with that “GP2” engine, so good luck against Red Bull Honda.
M840TR
313
Mark Hughes:
"Other team mates have been further off me than Stoffel," said Alonso. It's true. Here are the numbers:
Vandoorne ('17)+0.195%
Fisichella ('06)+0.224%
Grosjean ('09)+0.386%
Massa ('11)+0.427%
Massa ('10)+0.460%
Räikkönen ('14)+0.549%
Fisichella ('05)+0.550%
Piquet ('08)+0.598%
makecry
19
M840TR wrote:
14 Aug 2018, 12:05
Mark Hughes:
Massa ('11)+0.427%
Massa ('10)+0.460%
Piquet ('08)+0.598%
Those numbers are not accurate. Stoffel was further back.
rscsr
51
makecry wrote:
14 Aug 2018, 13:12
M840TR wrote:
14 Aug 2018, 12:05
Mark Hughes:
Massa ('11)+0.427%
Massa ('10)+0.460%
Piquet ('08)+0.598%
I just checked a couple of Qualifyings and it seems accurate.
Phil
66
Contact:
I'm betting he didn't see the '%' in the numbers...
#Team44 supporter
makecry
19
Phil wrote:
14 Aug 2018, 14:12
I did.
The numbers are not accurate at all.
The Stoffel's number for 0.195% is not accurate. Alonso out-qualified Vandoorne 16-3 with a median gap of 0.445%.The gap between them was significantly larger in the first half of the season (0.630% vs. 0.195%), while the tallies were similar (8-1 vs. 8-2).
He has pulled the number out of thin air after applying some really weird performance equalizers to his entire equation.
Lucky
156
Phil
66
Contact:
@makecry,
Well, I just did the math too and from 2017, I get a gap of 5.527 seconds (across 19 races) which equals 0.327%.
Did you compare the equal sessions? E.g. Alonso's Q1 with Stoffel's Q1, even if Alonso made it into Q2? If you didn't, track evolution etc might explain a more exaggerated gap. Perhaps Hugh also accounted for some sessions where either Stoffel or Alonso had obvious technical issues and thus prevented them of a fair fight. That could further minimize the gap.
Disclaimer: I'm not defending Hugh's numbers. But my roughly 10 minute job simply comparing all identical sessions between both drivers of 2017 reveal that the gap is indeed smaller than the 0.445% you are talking of. If Mark Hugh spent more time on his, who knows, they may be a more representative representation of the actual performances of the two, rather than just taking all numbers without context?
#Team44 supporter
rscsr
51
makecry wrote:
14 Aug 2018, 14:19
Phil wrote:
14 Aug 2018, 14:12
I did.
The median is not the average.
makecry
19
rscsr wrote:
14 Aug 2018, 15:03
makecry wrote:
14 Aug 2018, 14:19
Phil wrote:
14 Aug 2018, 14:12
I did.
Median is a better indicator. Average is not a good indicator when there are outliers.
makecry wrote:
14 Aug 2018, 14:19
Phil wrote:
14 Aug 2018, 14:12
I did.
I personally came to a difference of 0.354%. I included every qualifying session they both drove, so Q1 and Q2. I compared Q1 times to Q1 times and Q2 times to Q2 times. If for instance Vandoorne got knocked out in Q1 and Alonso did not, I would not factor in Alonso's Q2 time. Which is fair, conditions can quickly vary between Q sessions and to omit as many variables as possible, only the times they set in roughly the same period should matter.
Note I counted for every such session including the ones where Vandoorne had a readable downforce handicap. If I omit those, it drops to 0.268%.
GPR-A duplicate2
64
turbof1 wrote:
14 Aug 2018, 16:05
makecry wrote:
14 Aug 2018, 14:19
Phil wrote:
14 Aug 2018, 14:12
I did.
Does it make sense to compare Q1 and Q2? Unless, there are some situations like a driver couldn't move into Q2 or Q3 because of some weird issues. But otherwise, drivers typically leave a tenth or two in Q1 and Q2, just to keep some cards close to their chest, away from their team mate. It's always the Q3 (or Q2 for cars that find it hard to get into Q3) that reveals the ultimate potential of the driver-car combo.
Post Reply
