2018 Mercedes AMG Petronas Formula One Team
Post Reply
adrianjordan
Re: 2018 Mercedes AMG Petronas Formula One Team
Aren't people basically suggesting there's the absolute maximum power mode and then a mode that's just slightly more conservative than that?
Favourite team: McLaren
Quite probably, yes, there will be a qualifying mode, gates open, maximum deployment, minimum recovery.
And within that there will be nuances of it that have more or less aggressive timing/injection settings, etc, where the engine is run in the detonation region for Q3 mode and pulled back for reliability in Q1 and Q2
NL_Fer
82
saviour stivala wrote:
18 Jun 2018, 23:28
NL_Fer wrote:
18 Jun 2018, 20:36
That is normal qualifing mode, they use this for every stint in Q1, 2 and 3. But they use the most agressive version of it only in Q3, most of the time. Mercedes (and Ferrari also this year) are 0.3-0.5s faster in Q3. Drivers must anticipate for this.
So according to you Mercedes have two versions of “free load mode”, one more aggressive than the other! Maybe you care to explain how the more aggressive version works.
More agressive combustion.
Higher temps, in-cilinder pressure, maybe even some allowed knock. The can vary ignition/injection timing, increase turbo pressure. All is ofcourse at the expense of more engine wear and the chance of blowing up the engine.
taperoo2k
19 Jun 2018, 14:27
'Free load mode" is a mode intended to extract the maximum power output possible, so what is the scope of there being two versions, one more powerful than the other?.
It might be that one power mode is better than the other on certain tracks or it's more likely a case of Mercedes having a slightly less powerful mode to deploy as an ICE gets older so they can keep the damage to the ICE under control and ensure they don't have to replace an ICE earlier than planned if everything else has gone perfectly.
De Jokke
For those interested:
the 2.0 spec should give 1,5 tenth
the 2.1 spec should give 2 tenths
Lewis also talked about "lots of real positive developments coming through in the future" (for W09) but for now keeping our heads down.
Mercedes AMG + Hamilton => dreamteam!
If you can't beat'em, call Masi!
Big Tea
99
De Jokke wrote:
23 Jun 2018, 13:02
Is that compounded?
Ie the 2.1 engine 3.5 tenths on previous engine?
De Jokke
roon
412
De Jokke wrote:
23 Jun 2018, 13:02
That may have been why they weren't in a rush delivering the engine upgrades. They knew they had power units in the pipeline that would allow them to walk away with the rest of the season. If anyone's going to introduce unbeatable engines this season, it will be them. They've been doing it for four years, with this one odd delay that coincides with significant engine formula changes.
From earlier this year:
roon wrote:
22 Jan 2018, 23:01
Summary of some of the more interesting additions to the 2018 technical regulations. Revisions in pink.
dodds_turbo
Rumour has it Lewis has signed a new 2-year contract with Mercedes.
https://www.eurosport.com/formula-1/sea ... tory.shtml
Contact:
Only two more years?
#Aerogimli
I guess most of you already know this stuff but this might be interesting for some.
[media]https://twitter.com/MercedesAMGF1/statu ... 2920269825[/media]
Contact:
Gutted for those hard working team members in factories for double DNF today. Did Merc bring new gearbox with new PU?
#Aerogimli
Vanja #66 wrote:
01 Jul 2018, 16:56
Their last double DNF was 2016 Spanish GP for totally different reasons! Hamilton's last DNF was 2016 Malaysian GP which cost him the championship that year. It is very rare to see a Merc DNF, let alone two. And both were due to mechanical failures!
restless
Is there explanation for Hamilton's DNF? Gearbox or engine ?
restless wrote:
01 Jul 2018, 17:21
Loss of fuel pressure is what I found. I don't know if it's true or not
Post Reply
