2019 Aston Martin Red Bull Racing - Honda F1 Team
NL_Fer
NL_Fer
68
Re: 2019 Aston Martin Red Bull Racing - Honda F1 Team
HPD wrote:
Wed Apr 10, 2019 12:49 pm
Day 25. No one has seen me.. :-$
https://pbs.twimg.com/media/D3x7_-NXoAArk8K.jpg
@AlbertFabrega
Car 33 was behind the camera and Albon was 2 cars behind Norris, so nobody was visable from Honda crew. Idk, the reporter girl on the right, behind Saintz left rear? :lol:
ispano6
ispano6
165
Hamilton sees the Red Bulls as a threat for China. The really long straights here are going to help/hurt if cars are within DRS range. If the Red Bulls can keep out of DRS range they should be OK. Pierre says he's not as familiar with the track and Max hasn't had a good result here yet either. It's going to be a tough race for Honda and a good test to see how far they and STR have come since last year.
https://www.formula1.com/en/latest/arti ... mr2IP.html
“At the moment it’s clearly not just me and Sebastian,” he said. “So, I don’t see that changing any time soon. At the moment it’s at least four of us and the Red Bulls, you definitely can’t count them out.
“They’ve had a bit of a slower start, but I think if you look at last year for example they won the race here and they particularly finished strong. I anticipate it could be something similar.
“On the straights they’ve been really good so they are clearly, whereas they usually have a really strong car and not so strong engine, it’s the other way this year. They’ve got not as strong a car. But they’re one of the teams that can develop at a similar rate to Ferrari and us so it’s far too early to say.”
Snorked
Snorked
Verstappen to Dutch media said a pre-mounted part done at the factory was the cause of their troubles - what could this be, and are the cars shipped straight to Bahrain from Australia or do they go back to the factory?
Capharol
Snorked wrote:
Thu Apr 11, 2019 9:01 pm
if the cars would be shipped straight to Bahrain, RBR could have a little problem.... at least for this coming race 8) :lol:
Strive for continuous improvement, instead of perfection.
"Most people seem to turn off their brain when they turn on the computer and log in to social media."
Xero
68
I'd guess the suspension springs and dampers are pre-assembled, sounds like someone screwed that up.
Snorked
Snorked
Capharol wrote:
Thu Apr 11, 2019 9:32 pm
No, if the cars went from Australia to Bahrain they could have had this issue in both races, now that they found and fixed it hopefully Marko's two tenths off Ferrari becomes a reality 😁
Sayeman
45
Verstappen lost nearly 5 tenths in the third sector on his fastest lap. Also they mentioned the top speed was measly 308, not sure what the fuel level was.
Interestingly, Albon got upto 319 on the back straight, same as Williams.
Never Give up.
Ground Effect
Ground Effect
125
Sayeman wrote:
Fri Apr 12, 2019 4:53 am
Red Bull are trying out 2 different rear wings, Max was supposed to run more rear wing than Gasly.
Sayeman
45
Ground Effect wrote:
Fri Apr 12, 2019 5:00 am
Ah, maybe thats why he was so fast in the first 2 sectors and Gasly was so slow in the second sector
Never Give up.
McMika98
McMika98
-34
Its too early but car is competitive. Max was within few tenths on hardest tyres. His lap on soft didnt improve on final sector so there is room for improvement.
Gasly is aghastly poor again just above Kvyat.
Stef
Stef
Little mistake from Max in the last corner of his fast lap.
Marti_EF3
257
That's looking better than Bahréin at the moment. But until Q3, better to be cautious :)
Jaisonas
Jaisonas
Did Verstappen say he had a clutch issue while coming into the pits?
IvailoStefanovBG
37
Jaisonas wrote:
Fri Apr 12, 2019 9:11 am
Yes.
ThumbsUp
ThumbsUp
IvailoStefanovBG wrote:
Fri Apr 12, 2019 9:15 am
Yes.
After the training he said: It wasn't the clutch. There was a problem, but it wasn't a big problem
"Na de training vertelde Verstappen aan GPToday.net dat er inderdaad een probleem was, maar niet met de koppeling. "Er was geen probleem met de koppeling. Er was wel iets aan de hand, maar het was geen groot probleem.
https://www.gptoday.net/nl/nieuws/f1/24 ... -koppeling
But what the problem was isn't mentioned at all...
